hi I have added the following add-ons and none of them work is this to be expected?
demand 5 add on brings back a script error
even navi x launches and just sits at the please wait screen
is this what is to be expected the reliability of add-on tend to be useless spoiling the fun out of using xbmc I am based in the UK
any thoughts comments appreciated
Add-ons work with previous versions of XBMC.
Depends on what version you are. I'm on pre-frodo and gave up with those.
There are 'hacks' that may work for you, but doesnt for me.
Search google for "XBMC TVCatchup Add-On" to enjoy FreeView on your HTPC. Works with all versions.
The add-ons you've mentioned need updating to work with the latest Eden/Frodo builds.
You should keep your eye on the Add-Ons threads on here to see if they get updated.
(2012-10-21, 14:36)DejaVu Wrote: [ -> ]Add-ons work with previous versions of XBMC.
thankyou very much indeed topman dejavu thankyou
I was looking for a way to watch 4oD on xbmc again.
I followed the addon in your post but it doesn't give anywhere near the same functionality. In fact i think the name is plain misleading. It is called TVCatchup. It doesn't let you catch-up at all. It just lets you watch live streams.
Do you know a way to watch on demand TV?
Have you tried the latest version of the
4oD plugin?
