I see at git that there is a new version of pvr.hts and i think it may fix my EPG colours issue.
How do I compile and install that addon ?
Can i just compile the addon or do i need to comnpile the entire xbmc source (program and addon )?
ok guys i need some help here
Here is where i'm at currently
Quote:sudo apt-get install autoconf
sudo apt-get install libtool
git clone git://github.com/opdenkamp/xbmc-pvr-addons.git
cd xbmc-pvr-addons
sudo ./bootstrap
sudo ./configure --prefix=/usr/lib/xbmc
sudo make install
This ended up copying the addons folder to
/usr/lib/xbmc/lib/xbmc/addons
so I
cp XBMC_Tvheadend.pvr to /usr/lib/xbmc/addons/pvr.hts and rebooted. This ended in the plugin loading for a short moment and then xbmc going into a loop and crashing to command shell. What am i missing ?
(2012-10-23, 16:40)schumi2004 Wrote: [ -> ]Maybe this helps https://github.com/opdenkamp/xbmc-pvr-addons#readme
Thanks, followed that and I am close. But still not fully working.
If i do a
make zip i get the following file
pvr.hts-linux-i486.zip
pvr.hts
====addon
====resources
=====language
====dutch
====english
====finish
====german
settings.xml
addon.xml
XBMC_Tvheadend.pvr
====resources
=====language
====dutch
====english
====finish
====german
addon.xml
XBMC_Tvheadend.pvr
a couple of things i've noticed straight is i486 should possibly be i586 in filename for AMD athlon II x2 245 Processor and that there appears duplicate files in the archive.
Maybe @dushmaniac can help you since he is the developer of PVR addons.
Copied the folder over to ~/.xbmc/addons and installed a plugin (this usually updates the sources for me). Rebooted and low and behold the plugin was there at v1.10. I enabled the plugin and instant seg fault. Tried removing the addons data directory for a fresh install but no difference
Just deleted the source and tried again
cd xbmc-pvr-addons
./bootstrap
make zip
Copied the compiled zip (extracted of course) over to the ~/.xbmc/addons directory and rebooted. goes into a continues loop of crashing and reloading xbmc again
Tried deleting the TV21.db, EPG7.db and commoncache.db which stopped the loop but as soon as I reset the pvr database it started in the same loop again
This is using the latest pulse eight XBMC compiled on the 15th Oct, 2012
Try: Remove/rename in ~/.xbmc/addons and the same for the archived package in the package dir. Then install by zip.
Thanks for the suggestions Mizaki, I appreciate you trying to help. I did rename the dirs in ~/.xbmc/addons but same issue after installing the compiled zip. It just segfaults and goes into a constant loop
Well still having a devil of an issue getting the latest plugin to run after compile. I fresh installed, git cloned and compiled to zip again. Installed as per any other plugin and it does the same on enable, crash and reload xbmc in an infinate loop.
Can anyone link me to a recent compiled version of the hts plugin 1.10 i believe ? so i can see if this helps,
I'm now running the latest XBMCbuntu with the latest pvr compiled build from pulse eighty but was running a 10.4LTS live version.
The newer plugins won't work with Eden-PVR (Which is what the PE build is). You'll have to stick with older versions.
AH now that explains it
At least i can now stop banging my head against a brick wall thinking I was doing something wrong.
Thanks Begall
