Howdy folks.
I have several usb sticks with xbmc live (dharma) and I gave them away to my friends.
I have no way to update their sticks remotely, so they asked me to help them out with Youtube.
Now, I've noticed that there is no update for youtube for more than a month and plugin is not working.
http://mirrors.xbmc.org/addons/dharma/pl...o.youtube/
I would really appreciate if plugin can be updated or if anyone is willing to help me out fixing existing 2.1.4 version
Please don't abandon Dharma users
Cheers...
dharma will be abandoned completely when frodo hits the streets (we won't accept any pr's for it) so you may as well prepare now.
Hm, that's bad news :/
Then Eden will be abandoned, eventually Frodo and that's not something old folks like me can follow
I mean, I understand that unofficial addons are abandoned, but Youtube should work.
Anyway, thx for letting us know.
Can not understand why you not switch to a new xbmc version!
This Version is next step forward!
the problem is that many what before works example web scrapping better works with a up to date python Version and on Dhama its we on xbmc4xbox Version 2.4!
I have the Youtube 3.2.0 Addon adapted thats works on xbmc4xbox and with a little change it works on xbmc Dharma to .(it works on xbmc4xbox better as on Dharma)
But without Login!
I adapted the addons that we on xbmc4xbox have actuall addons from main xbmc whats works!
But better is we have a new python version (2.6 or 2.7) for xbmc4xbox!
You can have a new XBMC (Eden or Frodo) for you PC - you must nothing do as install the new Version!
And you have easy all what you want!
Regards Jan
I can, but my colleague in France doesn't know how.
My father is in Africa, he doesn't have a clue.
One friend from Latvia, one from Canada.
I installed to all of them, now they ping me everyday to fix youtube :/
Ok i help here is the Youtube 3.2 working solution for Dharma but its extensiell that with the new release from Frodo she change to it!
First install with the addon installer from xbmc self the script.module.parsedom from my zip
then install the youtube addon from my zip!
Make your setting and its works but without Login!
http://db.tt/fVU6BFj1
Regards Jan
Hi Jan,
thank you very much for your reply.
I will test it tonight, once I get back home.
They never used Login anyway
Will report back, thx
ok i hope its help , i have it tested on dharma !
regards jan
Yes!
Thank you Jan!
Works like a charm.
Your help is highly appreciated
Cheers mate
Need help with plugin in Dharma. For me this not working :-(
Search working but not play :-(
http://pastebin.com/92FaViSD
My PC is some old and only XBMC Dharma working in my hardware.
do not post logs on the forum.
Dharma is no longer supported. sorry
