Full Version: Crash - settings
I´m seeing crashes in the latest nightys. Occationally when watching videos, but always when navigating the settings
xbmc.log here: http://pastebin.com/raw.php?i=FxKyGYJE
os x crash log here: http://pastebin.com/raw.php?i=b2uZMxbj
I´m aware of nightly unstabillity, but I thought I´d share in case anyone can see something I can´t.
I´m using Aeon MQ4 by the way. I´d try another skin if only I could get into the appearance settings.
Could you remove your guisettings.xml (or move it away so you have a backup) and try again?
Hi thanks,
Deleting the guisettings.xml file got me back to a working default skin.
I guess there is a problem with MQ4 and the latest nightly then.
I tried reinstalling MQ4, but I get the same crash.
Can I get you more info, or should I get in touch with MarcosQui?
Edit: I't seems he is aware of it, and a fix is on the way:
http://code.google.com/p/mod-skin/issues/detail?id=261
