Can someone tell me what's wrong?
It was working ok except for a few plugins refusing to cooperate.
Was trying to get SuperTV to work since every channel I tried to watch it said working then flickered and back to menu so I tried turning the updated librtmp off in the settings of it and that's when it started.
It freezes after starting up and the autoupdate notification comes up.
I tried finding the supertv config and changed it back from false to true, didn't work.
Tried changing the librtmp to the one in the last supertv plugin i d/l'ed, nope.
Tried restoring the whole system to 2 days ago. nothing.
Hopefully someone can tell me what got messed up.
I put the log here
Pastebin log
Can you remove SuperTV and the repo listed below and see how XBMC works?
ERROR: XFILE::CFileCache::Open - failed to open source <http://xbmcaddons.com/dev-addons/andre/addons.xml.md5>
didn't think about that. Let me try.
Well it still does it. It starts up way faster but still freezes after the autoupdate.
It changed the log too.
Here's the new one....
Pastebin log
I would disable all theses addon as well:
10:54:35 T:5528 ERROR: C:\Users\StormFront\AppData\Roaming\XBMC\addons\script.trakt\utilities.py:19: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
import sha # Python 2.5 and earlier
10:54:35 T:8780 NOTICE: Update Library Service starting...
10:54:35 T:8780 NOTICE: service.libraryautoupdate: update timers
10:54:35 T:5528 NOTICE: [trakt] loading script.trakt version 1.0.1
10:54:35 T:6152 NOTICE: -->Python Interpreter Initialized<--
10:54:36 T:4780 NOTICE: Settings changed: False
10:54:36 T:8584 NOTICE: [What the Furk] Subscription service starting...
10:54:36 T:8584 NOTICE: [What the Furk] Updating video library
10:54:36 T:7708 NOTICE: StorageServer Module loaded RUN
10:54:36 T:7708 NOTICE: StorageClient-1.3.0 Starting server
10:54:36 T:7708 NOTICE: StorageServer-1.3.0 Storage Server starting C:\Users\StormFront\AppData\Roaming\XBMC\userdata\Database\commoncache.db
10:54:36 T:9488 ERROR: CRemoteControl::Connect - failed to connect
10:54:37 T:8716 NOTICE: VideoInfoScanner: Starting scan ..
10:54:37 T:4780 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/channels/format/json
10:54:37 T:8716 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
10:54:38 T:8584 NOTICE: [What the Furk] Next update is scheduled to run in 5h
10:54:38 T:5528 NOTICE: [trakt] json url: /account/test/b6135e0f7510a44021fac8c03c36c81a17be35d9
10:54:38 T:9088 NOTICE: Artwork Downloader: ## Service - Run at startup: False
10:54:38 T:9088 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
10:54:38 T:9088 NOTICE: Artwork Downloader: ## Service - Run as service: False
10:54:38 T:9088 NOTICE: Artwork Downloader: ## Service - Time: :00
10:54:38 T:8892 NOTICE: -->Python Interpreter Initialized<--
10:54:38 T:8892 NOTICE: [What the Furk...XBMCHUB.COM] mode=get subscriptions name= data= imdb_id=
10:54:40 T:4780 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2012-10-25/channel_id/59/format/json
It's still doing it.
I notice that even though i took out the Yousee.tv plugin it's still looking for the api for it?
I'm wondering now if it IS something i did or was it coincidence that it messed up just when I originally changed that add-ons setting.
This is the new log.....
Pastebin
Best, thing is to uninstall all your extra add-ons you installed and start fresh. Check all the different categories of add-ons especially the service addons.
Should I reinstall the whole program? And should I use one of the latest nightly builds?
Does the SuperTV work for anyone else using windows in the states? I love this program but really want to get these live plugins working and possibly get rid of cable..
So far all I was able to do is get a few of them working unreliably.
And is there an easy way to find live links on the net and easily add them to XBMC?
Thank you so much for this help kricker.
You need to check the support threads for those addons for issues with them.
If you want you could start with a fresh install. Using a nightly is totally up to you, unless one of the add-ons you want to use specifically need Frodo.
