2012-10-25, 21:40
Hello,
first of all, when I boot Windows 7, the IR is working fine!
I have the ASRock FM2A75 µATX board, which has a CIR port and I attached an IR module.
My remote is a Harmony 555 set to MCE Keyboard.
I am running minimal Ubuntu 12.10 (installed with the script from these forums) and installed lirc.
My hardware.conf is the following:
And my lircd.conf is:
dmesg shows the following:
ir-keytable shows the following:
ir-keytable -t and irw do not respond.
Can anyone help me?
REMOTE="Windows Media Center Transceivers/Remotes (all)"
REMOTE_MODULES="lirc_dev nuvoton-cir"
REMOTE_DRIVER="default"
REMOTE_DEVICE="/dev/lirc0"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="remotes/mceusb"
REMOTE_LIRCD_ARGS=""
include "/usr/share/lirc/remotes/mceusb/lircd.conf.mceusb"
[ 2.010534] Registered IR keymap rc-rc6-mce
[ 2.011090] input: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:04/rc/rc0/input2
[ 2.011160] rc0: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:04/rc/rc0
[ 2.016236] nuvoton_cir: driver has been successfully loaded
[ 2.024115] IR NEC protocol handler initialized
[ 2.028216] IR RC5(x) protocol handler initialized
[ 2.032897] IR RC6 protocol handler initialized
[ 2.036710] IR JVC protocol handler initialized
[ 2.049471] IR Sony protocol handler initialized
[ 2.052555] IR SANYO protocol handler initialized
[ 2.066880] input: MCE IR Keyboard/Mouse (nuvoton-cir) as /devices/virtual/input/input3
[ 2.066997] IR MCE Keyboard/mouse protocol handler initialized
[ 2.071116] lirc_dev: IR Remote Control driver registered, major 249
[ 2.076044] rc rc0: >lirc_dev: driver ir-lirc-codec (nuvoton-cir) registered at minor = 0
[ 2.076047] IR LIRC bridge handler initialized
Found /sys/class/rc/rc0/ (/dev/input/event2) with:
Driver nuvoton-cir, table rc-rc6-mce
Supported protocols: NEC RC-5 RC-6 JVC SONY SANYO LIRC other
Enabled protocols: LIRC
Repeat delay = 500 ms, repeat period = 125 ms
Can anyone help me?
