Full Version: How to detect usb storage ?
Hello , i try to write an addon that can read local directory and files
and i want to detect the usb storage that added or removed and refresh the video/music list immediately
i found two python modules named pyudev and pyusb , but it cant use in XBMC
when i try to run the addon , it always give me error.Sad
this is pyudev code below
PHP Code:
import pyudev
def check
(device):
context pyudev.Context()
monitor pyudev.Monitor.from_netlink(context)
monitor.filter_by('block')
observer pyudev.MonitorObserver(monitor,callback=check)
observer.daemon false
    observer
.stop()
observer.start()
this code can run on my machine , but cant in XBMC addon
what should i do furthor more? or any other solutions to detect usb storage?
You can start by telling what the error is. I imagine it's an import error because the only reason that code snippet work is because it does nothing. You need to put the pyudev module inside your addon.
I checked sys.path, the module path is included and i try to sys.path.append() but still cant.
my OS is ubuntu 11.04, i think the problem is not relatvie to the OS.
We still need to know what the error message is. We simply can't help you without it.
(2012-10-27, 20:24)Bstrdsmkr Wrote: [ -> ]We still need to know what the error message is. We simply can't help you without it.
when i write "import pyudev" in my python file , and execute XBMC to run my addon
it show plugin.video.xxxxx error, then i write sys.path to check the module is included or not
i have no idea to fix the problem. I had reference the xbmc python api document.
It seens not provide any function to detect usb storage.
the worst situation is that i must extend the APIs to do it by using libudev.h library.Sad
(2012-10-28, 08:19)beginerr0 Wrote: [ -> ]
What is being asked for is the output that your script puts into your xbmc.log file. XBMC outputs the traceback errors to the xbmc.log. This file is found in your ~\.xbmc\temp folder.
Quote:What is being asked for is the output that your script puts into your xbmc.log file. XBMC outputs the traceback errors to the xbmc.log. This file is found in your ~\.xbmc\temp folder.
here is my xbmc.log detail:it got some errors
08:23:37 T:2717907824 NOTICE: -->Python Interpreter Initialized<--
08:23:37 T:2717907824 DEBUG: Process - The source file to load is /home/hi/.xbmc/addons/plugin.video.videos/default.py
08:23:37 T:2717907824 DEBUG: Process - Setting the Python path to /home/hi/.xbmc/addons/plugin.video.videos:/usr/share/xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/hi/.xbmc/addons/script.common.plugin.cache/lib:/home/hi/.xbmc/addons/script.module.simple.downloader/lib:/home/hi/.xbmc/addons/script.module.keyboard.chinese/lib:/home/hi/.xbmc/addons/script.module.parsedom/lib:/home/hi/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/pymodules/python2.7/gtk-2.0:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/pymodules/python2.7/ubuntuone-client:/usr/lib/pymodules/python2.7/ubuntuone-control-panel:/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol:
08:23:37 T:2717907824 DEBUG: Process - Entering source directory /home/hi/.xbmc/addons/plugin.video.videos
08:23:37 T:2717907824 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.videos" dependent on version 1.0 of the xbmc.python api
08:23:38 T:2717907824 INFO: -->Python script returned the following error<--
08:23:38 T:2717907824 ERROR: Error Type: <type 'exceptions.IOError'>
08:23:38 T:2717907824 ERROR: Error Contents: (10, 'No child processes')
08:23:38 T:2717907824 ERROR: Traceback (most recent call last):
File "/home/hi/.xbmc/addons/plugin.video.videos/default.py", line 2, in <module>
import xbmc, xbmcgui, xbmcplugin, pyudev
File "/usr/local/lib/python2.7/dist-packages/pyudev/__init__.py", line 46, in <module>
from pyudev.device import *
File "/usr/local/lib/python2.7/dist-packages/pyudev/device.py", line 35, in <module>
from pyudev._libudev import libudev
File "/usr/local/lib/python2.7/dist-packages/pyudev/_libudev.py", line 289, in <module>
libudev = load_udev_library()
File "/usr/local/lib/python2.7/dist-packages/pyudev/_libudev.py", line 270, in load_udev_library
udev_library_name = find_library('udev')
File "/usr/lib/python2.7/ctypes/util.py", line 236, in find_library
return _findSoname_ldconfig(name) or _get_soname(_findLib_gcc(name))
File "/usr/lib/python2.7/ctypes/util.py", line 229, in _findSoname_ldconfig
f.close()
IOError: (10, 'No child processes')
08:23:38 T:2717907824 INFO: -->End of Python script error report<--
08:23:38 T:2717907824 INFO: Python script stopped
08:23:38 T:2717907824 DEBUG: Thread XBPyThread 2717907824 terminating
08:23:38 T:3042060080 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
08:23:38 T:3042060080 ERROR: GetDirectory - Error getting plugin://plugin.video.videos
08:23:38 T:3042060080 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.videos) failed
08:23:38 T:3042060080 DEBUG: waiting for python thread 1 to stop
08:23:38 T:3042060080 DEBUG: python thread 1 destructed
08:23:38 T:3042060080 DEBUG: waiting for python thread 2 to stop
08:23:38 T:3042060080 DEBUG: python thread 2 destructed
08:23:38 T:3042060080 DEBUG: waiting for python thread 5 to stop
08:23:38 T:3042060080 DEBUG: python thread 5 destructed
(2012-10-29, 10:08)takoi Wrote: [ -> ]http://trac.xbmc.org/ticket/12098 ?
so it's a bug when call external python module!?
or any other way to solve usb storage detect problem and refresh list !?maybe i need some hints to do,if the way cant...Huh
i had already try python mutlit-thread and modify the xbmcmodule.cpp ,but util now still useless. Confused
No, generally external modules work. But clearly find_library fails. Either it's xbmc doing something or find_library not finding the library. The error message sure is obscure.
I had already try detect usb flash for few days but still failed
now i modified xbmc source code to extend Python APIs in xbmc python module
I use libudev C library, and in my addon , my code like as below
PHP Code:
while True:
result xbmc.USB_Detect()
    if
result == 1:
xbmc.executebuiltin('RunAddon(plugin.video.videos)')
result 0
    time
.sleep(3
USB_Detect function can run correctly, when i plug the usb media in or out, it can return result
but both xbmc.executebuiltin() or xbmc.executescrpit() not executed, my UI did not do anything. Why?
