Line 295:
if (!CFile::Exists(strIconPath) && !strIconPath.IsEmpty())
return false;
Should be:
if (!CFile::Exists(strIconPath) && strIconPath.IsEmpty())
return false;
Reg.
Fred
it's a bug, but your fix isn't correct either. but thanks for pointing it out
(2012-10-26, 11:23)dushmaniac Wrote: [ -> ]it's a bug, but your fix isn't correct either. but thanks for pointing it out
I was loosing my icons for the radio channels each time I started xbmc
(2012-10-26, 11:47)Skixbmc Wrote: [ -> ] (2012-10-26, 11:23)dushmaniac Wrote: [ -> ]it's a bug, but your fix isn't correct either. but thanks for pointing it out
Well, now I have no icons at all
but I think that the problem can be resolved with the following solution:
First:
bool CPVRChannel::SetIconPath(const CStdString &strIconPath, bool bIsUserSetIcon /* = false */)
CSingleLock lock(m_critSection);
if (m_strIconPath != strIconPath && CFile::Exists(strIconPath))
/* update the path */
m_strIconPath.Format("%s", strIconPath);
SetChanged();
m_bChanged = true;
/* did the user change the icon? */
if (bIsUserSetIcon)
m_bIsUserSetIcon = !m_strIconPath.IsEmpty();
return true;
return false;
Why?
Because this function is called from CPVRChannelGroup::SearchAndSetChannelIcons which do a OR call on the different image types.
Second:
/* skip if an icon is already set */
if (!groupMember.channel->IconPath().IsEmpty() && CFile::Exists(groupMember.channel->IconPath()))
continue;
This is an second control of the file exists.
There is also another problem with assigning the icons manually, the setting isUserSetIcon is not set and there is no check when loading the channels to obey this settings.
Reg.
Fred
meh, forgot about that sucky SearchAndSetChannelIcons() method
Why is line 295 a problem? I added that because without "&& !strIconPath.IsEmpty()" the icon could never be removed once it was set.
And about the isUserSetIcon... it is set when user is choosing an icon from GUIWindowPVRChannels. And checked when the channels are loaded from the backend (so that the user set icon is not overwritten). Maybe it's missing in CPVRChannelGroup::SearchAndSetChannelIcons... i'm not sure because I never used this function.
You can take a look here to see what was changed when this was commited:
https://github.com/opdenkamp/xbmc/commit...4fa39dda63
Please describe your use case and problem... and then I'll take a look in how to fix it (without breaking anything else).
(2012-10-28, 09:41)mikrohard Wrote: [ -> ]Why is line 295 a problem? I added that because without "&& !strIconPath.IsEmpty()" the icon could never be removed once it was set.
Yes,
That is how it should be, but I have the code from github/xbmc and there it is different.... I thought that the pvr code was integrated in xbmc...
It was integrated... but it's already 8 months since this was added to Eden-pvr. It was likely modified before being merged into mainline.
(2012-10-28, 10:41)mikrohard Wrote: [ -> ]It was integrated... but it's already 8 months since this was added to Eden-pvr. It was likely modified before being merged into mainline.
That explains a lot to me, but which repo should I take?
(2012-10-28, 10:44)Skixbmc Wrote: [ -> ] (2012-10-28, 10:41)mikrohard Wrote: [ -> ]It was integrated... but it's already 8 months since this was added to Eden-pvr. It was likely modified before being merged into mainline.
So I take the repo from xbmc and the pvr files from opdenkamp and merge the files?
No... it's already merged into mainline. I just wanted to show you the commit to see what was changed at that time.
Just take xbmc master (frodo) and fix it there if it's broken. Or let someone else fix it...
mainline xbmc = alpha state. take eden-pvr from my repos if you want a stable build
