Allrighty then, thnx. I'll try..
I have a strange issue with this add-on and radio add-on. Both of them take up to 5 minutes to start playing an audio stream. This happens on all 3 of my Windows XBMC installs. Any idea what could cause this?
12:41:28 T:5476 DEBUG: CFileCache::Open - opening <service> using cache
12:41:28 T:5476 DEBUG: CurlFile::Open(0C9E9F10) http://192.168.0.4:8866/service?method=recording.list&filter=pending&sid=b5adc62014cc4c20bedcf41e6c672419
12:41:29 T:4332 NOTICE: Thread CFileCache start, auto delete: false
12:41:29 T:4332 INFO: CFileCache::Process - Hit eof.
12:41:29 T:4332 DEBUG: Thread CFileCache 4332 terminating
12:43:38 T:6056 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/libmad.dll)
12:43:38 T:6056 DEBUG: CFileCache::Open - opening <> using cache
12:43:38 T:6056 DEBUG: CurlFile::Open(0CD98548) http://94.23.56.161:80/
12:43:39 T:6056 DEBUG: CurlFile - file <http://94.23.56.161:80/> is a shoutcast stream. re-opening
12:43:39 T:6056 DEBUG: File::Open - redirecting implementation for http://94.23.56.161:80/
12:43:39 T:6056 DEBUG: CurlFile::Open(0CB03B68) http://94.23.56.161:80/
12:43:39 T:6324 NOTICE: Thread Shoutcast file start, auto delete: false
12:43:39 T:3772 NOTICE: Thread CFileCache start, auto delete: false
12:43:40 T:6056 INFO: AudioDecoder: File is queued
12:43:40 T:6056 INFO: CSoftAE::MakeStream - AE_FMT_S32NE, 44100, FL,FR
12:43:40 T:7052 DEBUG: CSoftAE::Run - Sink restart flagged
12:43:40 T:7052 INFO: CSoftAE::LoadSettings - Stereo upmix is enabled
12:43:40 T:7052 DEBUG: CAESinkDirectSound::IsCompatible: Formats compatible - reusing existing sink
12:43:40 T:7052 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
12:43:40 T:7052 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
12:43:40 T:7052 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
12:43:40 T:7052 DEBUG: AERemap: Downmix normalization is disabled
12:43:40 T:7052 DEBUG: CSoftAEStream::CSoftAEStream - Converting from AE_FMT_S32NE to AE_FMT_FLOAT
12:43:40 T:6056 DEBUG: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 0.000000
12:43:40 T:6056 INFO: PAPlayer::PrepareStream - Ready
12:43:40 T:6688 NOTICE: Thread PAPlayer start, auto delete: false
12:43:40 T:6688 DEBUG: PAPlayer::Process - Playback started
12:43:40 T:6056 DEBUG: CGUIInfoManager::SetCurrentSong(http://94.23.56.161:80)
12:43:40 T:6056 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://94.23.56.161
12:43:40 T:6056 DEBUG: CCurlFile::GetMimeType - http://94.23.56.161:80/ -> audio/mpeg
12:43:40 T:6056 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
12:43:40 T:6056 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
12:43:41 T:6056 DEBUG: CCurlFile::GetMimeType - http://94.23.56.161:80/ -> audio/mpeg
12:43:41 T:6056 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
12:43:41 T:6056 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
12:43:41 T:6056 DEBUG: waiting for python thread 6 (D:\HTPC\Xbmc\portable_data\addons\plugin.audio.shoutcast\addon.py) to stop
12:43:41 T:6056 DEBUG: python thread 6 (D:\HTPC\Xbmc\portable_data\addons\plugin.audio.shoutcast\addon.py) destructed
12:43:41 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
12:43:41 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
12:43:42 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
12:43:42 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/swscale-2.dll)
12:43:43 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
12:43:43 T:6056 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avfilter-2.dll)
In the above log snippet you can see where it took ~2 minutes to start playing the stream.
After some testing it appears that my using a MySQL music database causes my issue. When I remove that from my advancedsettings.xml file the streams playback within seconds. The question now would be, why does this happen?
(2013-02-16, 19:47)kricker Wrote: [ -> ]After some testing it appears that my using a MySQL music database causes my issue. When I remove that from my advancedsettings.xml file the streams playback within seconds. The question now would be, why does this happen?
I'm suffering the same issue but have used a MySQL music database for quite sometime. The problem with the delay in opening a radio stream began 1 - 2 weeks ago. I mostly listen to shoutcast nowadays so maybe I'll discontinue use of the MySQL database for music.
I would say that the delay started occurring around the same time as when I updated to the latest XBMC (Frodo), but couldn't say for certain...
I can't say either. I'll need to install an old build and see how it behaves.
I don't think that the issue you describe is really add-on related. I know that XBMC saves some data in the database when you start playback.
After figuring out what the issue is I agree. I need to investigate elsewhere.
I tried your method of removing the MySQL music database and Shoutcast was a bit quicker but it still took 20-30 seconds to load each step in finding a station (by genre, choose genre, choose station).
I've also tried pinging shoutcast.com from my XBMC computer and another computer (on the same network) and neither of them return a ping in a satisfactory amount of time. I can go to
www.shoutcast.com with no delay, but pinging doesn't work. Can a domain disallow pings??
Fantastic Plugin. thank you!!!
Just a side note I noticed while playing stations, I don't know if this is an xbmc thing or not, but if I play a station and click on another station to play, it will not play the station but rather it will add it to the queue. I flipped over to the now playing/queue and the station id number is listed for both stations but I have to click on the second station to play it from there. Is there any way to allow each radio station to play once I click on it and not have it queue the station so I have to perform the aformentioned steps, from within the add-on? This is a minor user interface thing, overall very good design and layout!
Thanks and keep up the solid work sphere, love to see what you can do next!
Jules
Don't you have Queue Songs On Selection enabled under Audio in settings?
(2013-02-19, 21:56)schumi2004 Wrote: [ -> ]@Jules
Yes it is checked, would this be why it is doing that? If I am currently listening to a station and I want to listen to another station, when I click on the other station it queues it directly but does not play the new station until I go into the queue and click on it. I do not want to lose the queue functionality elsewhere/.
