Full Version: 2 things on ReFocus that I need help with...
Is there a way to go into Movies and then push backspace once to get back to the home screen? Right now it brings me to a submenu that I don't want to see. If there has been a fix for this already does anyone have a link? I can't find anything on the subject.
Here is a 16 second video of this first problem:
http://minus.com/lbzDzG4Dlposb7
And also, with addons, is there a way at the home screen to push "Add-ons" and then immediately go to a grid view for the addons?
Here is an 8 second video of what I want. I guess i'm wondering if it's possible to put a custom button on the homescreen that will bring me directly to a grid view of the addons.
http://minus.com/lkKGBVQhSMuQX
Download 'refocus big' mod there is an option in skin settings for this.
(2012-10-29, 03:34)loggio Wrote: [ -> ]Download 'refocus big' mod there is an option in skin settings for this.
Just downloading it and can't seem to find the setting... Think I could get some help?
Ok so I seemed to at least find the add on problem... partly. The grid icon view is only when you have the "Video" section on the homescreen enabled... I usually have it hidden.
Is there a way to basically have an "Add-on" button on the homescreen that will take me right to the grid view for addons?
And does anyone know of a way to fix that first problem I'm having in the original post?
Skin settings, you can do it there.
I'm having this too, where is it in skin settings?
(2012-10-29, 05:17)jeremytodd1 Wrote: [ -> ]Ok so I seemed to at least find the add on problem... partly. The grid icon view is only when you have the "Video" section on the homescreen enabled... I usually have it hidden.
This will fix the first problem: http://forum.xbmc.org/showthread.php?tid...pid1053109
from the video i can tell you used a keyboard so instead of pressing backspace try pressing escape or esc this will take you straight back to the main menu the issue is backspace takes you back to previous folders or up one level whereas escape goes all the way back
i have programmed my mce remotes to fix this issue
