Hi.
I have download Square.7z from GITHUB download section, extract square.xbt and copie it in media folder.
But how can I enable square theme ? I didn't have see any option in Skin settings.
Is there any way to know that square theme is used ?
I have look into guisettings.xml and found :
<lookandfeel>
<enablerssfeeds>true</enablerssfeeds>
<font>Default</font>
<rssedit></rssedit>
<skin>skin.aeon.nox</skin>
<skincolors>Square.xml</skincolors>
<skinsettings></skinsettings>
<skintheme>Square</skintheme>
<skinzoom>0</skinzoom>
<soundskin>SKINDEFAULT</soundskin>
<startupwindow>10000</startupwindow>
</lookandfeel>
But I need to read this setting for my mod to use square case instead of rounded one.
And I guess that Skin.HasSetting can't access this kind of setting :S
No need of knowing if square theme is enable.
Just have to put PNG in the right directory :
\media\square\thumbs\boxes\tvshows
phil65 or Big_Noid : Is it possible to get a ZIP file instead of XBT, I need CD square case
(2012-10-29, 15:16)mikebzh44 Wrote: [ -> ]No need of knowing if square theme is enable.
@phil65 or Big_Noid : Is it possible to get a ZIP file instead of XBT, I need CD square case
/themes/square/....
you can convert that to an xbt then with texturepacker.
Mike: just unzip these files to your nox folder, then run packer.bat file...
These files packed just square theme to .xbt, to your media folder..
You put your modified files to: Themes\Square folder before use that..
Allways when you will any new try, just delete old square.xbt, and run packer.bat
Cheers
