Full Version: Compile xbmc-pvr-addons for ATV2
already searched a little bit around here in the forums, but only found information for building XBMC for ATV2.
Is it possible to compile the xbmc-pvr-addons standalone for the ATV2?
If not, I'm able to setup a build enviroment under OS X, but what has to be done to compile the plugin during the build process of XBMC for iOS.
Any advise is appreciated.
Thx!
You should rename the title from "VU+" to "xbmc-pvr-addons". After all this is not really limited to the VU+ / Enigma2-Addon, isn't it?
(2012-10-29, 16:25)jdembski Wrote: [ -> ]You should rename the title from "VU+" to "xbmc-pvr-addons". After all this is not really limited to the VU+ / Enigma2-Addon, isn't it?
Thanks for the hint, done!
Found this from davilla:
make -C tools/darwin/depends/xbmc-pvr-addons
once you setup to build.
So I think I have to clone the official git repo and then have to compile all pvr plugins.
