2012-10-29, 21:30
First of all. Love the skin.
Now to the problem.
Is there anyway to make transpareny use "remote" fanarts as deafult instead of "local" = fanart.jpg in the folder.
Reason for this is that I put together an htpc for the kids. And it would be nice to make it just update the fanarts same way as it does with the thumbnails. 100+ movies are alot to update manually.
Is there an easy way to do this or should I aim to use another skin that do that, for that htpc ?
Now to the problem.
