Full Version: XBMC Confluence menu settings
Im using the confluence skin on an ATV and had to recently re-add all of my media folder locations from my PC.
I went into add source and added my movie folder via SMB shares. I selected (Movies) as the type of source and (TV Shows) for my Tv shows folder. but instead of these two options appearing on the main menu they appear as sub headings under the VIDEO heading next to add ons, files etc. They originally used to appear as main headings so I would have the following.
WEATHER-PICTURES-MOVIES-TVSHOWS-VIDEOS-MUSIC-SETTINGS-PROGRAMS (or similar)
Now I have
WEATHER-PICTURES-VIDEOS-MUSIC-SETTINGS-PROGRAMS
TV shows-Movies-add ons-files
How do I get the movies and tv show folders back in the main menu?
Try the following: System/Settings > Skin > Home window options > Uncheck "Hide - Movies" and "Hide - TV shows"
Im sure they are already unchecked but I will check when I get home tonight. Thanks.
You need to set content type for each source and then scan them to the library. Once xbmc has added them to the library movies and tv on the home screen will become visible. Right click or press C then select set content.
