Full Version: Problem customising the Confluence Home Menu
Hi.
I am a fairly new user of XBMC and it seems absolutely brilliant.
I also find it fairly frustrating trying to understand the way everything works and seems dirfferent with different skins.
I must admit I get a bit lost sometimes!
I am trying to customise the start menu on the Confluence skin and I seem to be a bit stuck!
My menu structure is
HOME CINEMA-
- MOVIES
- 2D MOVIES
- Movie1
- Movie2
- Movie3
- 3D MOVIES
- Movie4
- Movie5
- TV
- TV Series 1
- TV Series 2
- MUSIC
- PICTURES
I have created the following 2 xml files to create the smart playlist
1. 2dmovies.xsp
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="movies">
<name>2D Movies</name>
<match>one</match>
<rule field="path" operator="contains">2D MOVIES</rule>
</smartplaylist>
2. 3dmovies.xsp
<name>3D Movies</name>
<match>one</match>
<rule field="path" operator="contains">3D MOVIES</rule>
</smartplaylist>
and put it in the folder
<User>/Application Data\XBMC\userdata\playlists\video
I added the following entry into the home.xml file in the Confluence skin folder.
<item id="18">
<label>2D Movies</label>
<onclick>ActivateWindow(10025,"special://profile/playlists/video/2dmovies.xsp", return)</onclick>
<icon>special://skin/backgrounds/city-landscape.jpg</icon>
</item>
<item id="19">
<label>3D Movies</label>
<onclick>ActivateWindow(10025,"special://profile/playlists/video/3dmovies.xsp", return)</onclick>
</item>
The menu items "2D Movies" and "3D Movies" now appear on the home menu bar but when I select either of them the list is empty.
Is there something I've missed?
What happens if you open the playlist via Videos--->Database--->Playlists?
(2012-10-31, 16:34)mad-max Wrote: [ -> ]What happens if you open the playlist via Videos--->Database--->Playlists?
Hi
Thanks for the reply.
It's the same blank.
I have been researching the problem and I think the cause might be that I am working offline.
I am playing around with XBMC trying various skins and options so I have been installing/uninstalling XBMC at various times.
However I have not got an Internet connection.
As I am working offline I presume the XBMC database is not getting populated as I obviously always get the error message
"Unable to connect to remote server".
If I look at it in FILE mode I can see all my folders and files.
Is this the problem?
If Yes then is there any way to refresh the database offline?
If you did not populate your database, then it's obvious...
Smartplaylists are only working with a library...
If your offline you can try to create local NFO Files like this:
http://wiki.xbmc.org/index.php?title=Imp...ary#Movies
mad-max
Hi
Thanks I'll give that a try.
I'm home now so I have Internet access.
I have built the library and the menu seems to work as I expected.
I will be working again offline in the future.
Which Folder/Files do I need to take with me to ensure that I have my library portable so I can play around with the settings?
Which is the database file(s) and associated file(s)?
Peter
