Hello I setup a simple
playercorefactory.xml to start TMT for the 3D iso file:
<playercorefactory>
<players>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Lucas\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO -->
<rule filenames="*3D*.iso" filetypes="iso" player="ISO_Player"/>
</rules>
</playercorefactory>
All working fine, except for the fact that ALL the ISO files are played with TMT. So seems the filter *3D*.iso doesn't work.
Could some one point me to a solution?
Example:
MOVIE1.ISO
MOVIE2.ISO
MOVIE3 3D BLABLA.ISO
MOVIE4 3D BLABLA.ISO
So I would like to start TMT only for MOVIE3 and 4.
Lucas
Try this rule (<rule filetypes="iso" filename=".*3d." player="ISO_Player"/>) instead.....
(2012-11-01, 00:49)bluray Wrote: [ -> ]Try this rule (<rule filetypes="iso" filename=".*3d." player="ISO_Player"/>) instead.....
Thanks for reply bluray....
Well, this will drive me crazy!!!!
1) With => filename=".*3d." => This will not never start TMT
2) With => filename=".*3D*." => This seems to work but with some exceptions.
Let me report some "real" filename as example for rules Nr.2
Lego Star Wars.iso" => This is
OK. XBMC used internal player
Nati con la camicia.iso" => This is
Viaggio nell'isola misteriosa 3D [2012].iso" => This is
OK. XBMC used external player (TMT)
John Carter 3D FULL BLURAY.iso" => This is
[1937] - I Fanciulli del West.iso" => This is
NOT OK. XBMC used external player (TMT)
[1935] - GLi allegri Scozzesi.iso" => This is
WTF!?!? Why for the last two XBMC starts external player ?!?!
With this (<rule filetypes="iso" filename=".*3d." player="ISO_Player"/>) rule, you have to name your blu-ray ISO this way (Avatar 3d.iso).....other iso's will playback using XBMC....
Thanks bluray, now it works. I had to rename all the BD3D iso I have to "XXXX 3D.iso" and then rescrap them, but now it works.
But honestly I cannot understand why this works => ".*3D."
And this not => ".*3D*."
I'm asking because I would like to understand how the filename works in the rules, and just in case I need to create further rules with different filename!
