2012-11-01, 12:32
2012-11-01, 14:37
Play without subs http://forum.xbmc.org/showthread.php?tid...pid1048888
In your case you want to disable make sure its unchecked then Save for all videos will save this option for all videos :/
Sync subs is the subtitles offset setting
uNi
uNi
2012-11-01, 22:37
I suppose it depends on what kind of subs you are working with?
scott s.
scott s.
2012-11-01, 22:43
If your video source is a container file and it contains subtitles correctly added, or if you're using a separate sub/idx subtitle file, then xbmc OSD should be able to turn them off. If your video has them hardcoded into the video, then there's nothing you can do.
