Full Version: YouTube Play on XBMC Bug Report
I like the Play on XBMC feature that you have inside the Android YouTube application.
The only problem is that sometimes when I'm in the YouTube application and I hit the share button and then "Play on XBMC" it doesn't work, and I believe I know what the problem is.
The "Play on XBMC" feature sends just the part of the id if it encounters a minus "-" sign inside the YouTube id.
For example
I have this id:
zaP9-tKleRg
And it tries to play:
zaP9
As you can see, that is not the complete YouTube id and that's why this "Play on XBMC" doesn't work.
Is this the correct way to report a bug?
Should I do something else?
