Full Version: DialogBusy.xml
Hey Jezz
Just a query, I notice the window ID of DialogBusy.xml in Confluence is 136, but the wiki page for Window ID's says it should be 138. Is this a hiccup in Confluence ?
yeah I wouldn't worry about it they are not used by the C++ infact jmarhall told me to remove them from all the windows xml but the custom ones and really you should be using the "english names" in the wiki if your checking for conditions with it
Yep, I was setting up animations to use "english names" when I noticed it. No problems then Smile
