2012-11-04, 03:26
Hello,
I have been using the last september nightly (64 bit) for some time now, and today I tried to change it to the last nightly of october (tried both of 30th and 31st), but when using it XBMC freezes at the XBMC logo. I tried waiting quite a while once, but nothing seemed to happen and I just killed the XBMC process and tried again or other builds. This essentially means that I cannot use these latest nightlies of XBMC at all, and I am wondering if there is something you know about that I could do to make it work? I have tried a lot of different builds now, such as a october 25th build and it had the same thing. Tested november 1st and 3rd (32 bit and 64 bit) builds, same problem.
However, if I go back to my september 30th 64 bit build, XBMC is back to normal without freezing when showing the XBMC logo before it let's you access the familiar menu we all know.
Mac Mini with AMD GPU and Mountain Lion 10.8.2 (it did not work with 10.8.0 either).
It's very late for me at the moment and I need some sleep, therefore my post will lack links to logs, but if there is something obvious you know about, I would like to know. Otherwise, I will post logs and more detail after some sleep.
Thank you for your time.
