Full Version: Frodo-support?
Hello
12.0/Frodo isn't supported, right? I installed a nightly yesterday but XBMC Remote stopped working.
Rgds
A 2 sec search would have give you the information Smile
You can use Tom. builds available at : https://github.com/tombriden/android-xbm.../downloads
Or try alternatives.
(2012-11-04, 13:03)Tolriq Wrote: [ -> ]A 2 sec search would have give you the information Smile
Still getting the same error though. The remote works but that's it.
Same here.
I am using 12.0 beta1 on ubuntu
It's been updated today and it seems to be working fine :-)
Now XBMC (frodo) crashes at downloading thumbnails.
Later I will try a newer build.
the newest build works with Frodo. I get an error message if I try to play some music, but XBMC still starts playing.
Thx
Yatse
Works good for me know, great, thanks!
