Full Version: wireless connected but no internet access
Hi there,
I'm a near-complete linux noob. I have a Shuttle XS35GT V3 with the current build of XBMCbuntu Eden installed.
Today after hours of operation, the wireless simply stopped working. Here's what I know:
- when running XBMC from XBMCbuntu, wireless would periodically prompt me for password as it had disconnected
- while I was in XBMC, wi-fi disconnected entirely
- system tray icon shows the up and down arrows that indicate network connection, but chromium says I can't connect to the internet.
- In the right-click menu for that up and down arrow icon, neither "networking" nor "wireless" are enabled, and enablign them does nothing
- If I click "connection information" I get a dialogue box telling me "error displaying connection information: No valid active connections found"
- rebooting doesn't fix it
- I've made sure my NetworkManager.conf has "true" set for the value that means nm manages my connection.
- connecting via ethernet cable doesn't work either
I have literally no idea what caused this or how to fix it.
I know the done thing around here is that I type a bunch of stuff into terminal and report it to you, but don't even know what to type into terminal or how to get it to output to a file so I can copy-paste it to here.
Any help much appreciated!
Hello and welcome to forums.
I dont use wireless but hers something you can try!
1- Ca you connect from another wireless machine i.e. is your wireless router working and do you have internet connection?
2- Reboot your router and modem and wait for everything to come up, reboot your xbmc box
3- Type ifconfig on terminal and post the result here in [code brackets]
3- Determine the name of the adapters that ifconfig spat out
This is presuming your adapter is named vlan0 some are ra0
ifconfig wlan0 down
ifconfig wlan0 up
then try restarting networking
sudo /etc/init.d/networking restart
This is all presuming your internet is on and that your wireless is working.
If not try this https://help.ubuntu.com/community/WifiDocs/WiFiHowTo
also maybe consider this http://wiki.xbmc.org/index.php?title=Add...rk-Manager
uNi
(2012-11-07, 14:03)boots Wrote: [ -> ]- connecting via ethernet cable doesn't work either
(2012-11-07, 14:57)uNiversal Wrote: [ -> ]also maybe consider this http://wiki.xbmc.org/index.php?title=Add...rk-Manager
Just asking myself how to add something from the internet without having an internet connection....
