Full Version: remote that works with ipod touch 1g?
I looked all over for an xbmc remote that will work with IOS 3.1.3 which is the highest I can run on my touch 1g. Couldn't find anything, found a couple that supposedly work with older versions of xbmc, but they didn't work for me when trying with the latest build. Thanks if you know of something.
I think your only option will be to use a web based version. You will find those in the Web interfaces.
