Full Version: remote access to xmbcbuntu with mac
Hi all,
this should be a more than answered question but I've made several searches without luck Sad
so I've a mac with x11 and a PC with xmbcbuntu installed, I can do ssh -X -Y [email protected]
there is any way to open a graphical user interface to manage the xmbcbuntu? move files arround.. without using shared folders?
I've tried this with no luck..
sudo startx
Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again.
Can someone help? thanks in advance.
Hello and welcome to the forums. My single serving friend. Big Grin
I dont use any of what your using nor xbmcbuntu nor vnc but I stumbled upon this in my travels. http://forum.xbmc.org/showthread.php?tid...pid1231002
Hope it helps
uNi
Hi uNi!
thank you for the quick reply! tonight I'll try it Smile
Cheers
I think the only thing you need is Putty with enabled X11 forwarding:
http://hints.macworld.com/article.php?st...5004004268
Every launched GUI application will just show up on your mac. I always work remotely on my Linux systems using Putty and CygwinX on a Windows client.
EDIT: sorry, the link was for getting mac GUI to Windows. You might not need any additional tools. From a machine with an X server you can log in to a remote machine and forward X11.
