2012-11-14, 19:25
Howdy All,
I'm a relative new comer to XBMC, but the wiki & guides have all been a great help. I've added all my movies without issue, but I can't get my TV Shows in correctly. Only a couple of the 60 something shows get recognized (so far, the most shows that have been "added" is 4). All the other episodes end up in a single directory - by season. Looks something like this:
I have all of my media on an unRaid server on shares that are available via NFS. My movies collection works fine attached as an NFS share. I can see everything on my TV share when attached via NFS as well - but it doesn't get added correctly.
The folder structure on the server looks like this:
I've read these instructions on Name files/TV Shows and it seems that the [Show]\[Season]\[Episode] convention that I follow is not what XBMC wants? (because the first example in the wiki shows [Media]\[Show]\[Episodes] - no season folders). However, later in the wiki it does talk about custom naming (section 7.2) and using the advancedsettings.xml file. I added this file along with the regex given in the first example under 7.2. I added the file in the /userdata/ folder as indicated in this wiki entry for advancedsettings - with the contents:
However, that didn't fix the issue.
So far none of the variations I've tried has helped. Finally, I removed the existing TV Shows library last night, shut everything down, and was going to give it another shot tonight. I'm hoping for a little bit of guidance that may help me get everything working correctly.
Here is the pastbin for when I added my shows via NFS - http://xbmclogs.com/show.php?id=14468. I did look at the log and I see an error repeating - "NFS: Lookup of //Media failed with NFS3ERR_NOENT(-2)". I found an issue logged on github that sounds similar - Possible NFS Race condition even though it is about Raspberry Pi/Xbmc - it even suggests that mounts made "Using OS-level NFS mounts (ie. mounting via /etc/fstab)" always work reliably as compared to mounts established in XBMC.
So my questions are:
Thanks in advance for any suggestions.
~Whip
.. <-- it shows as ".."
Season 1
Big.Bang.Theory.s01e01.Episode.Name.mkv
Dexter.s01.e01.Episode.Name.mp4
The.Tudors.s01.e01.Episode.Name.mkv
Season 2
Big.Bang.Theory.s02e01.Episode.Name.mkv
Dexter.s02.e01.Episode.Name.mp4
The.Tudors.s02.e01.Episode.Name.mkv
Media
-------->Big Bang Theory
----->Season 01
----->Show.Name.s01e01.episode.name.mkv
----->Show.Name.s01e01.episode.name.tbn
----->Show.Name.s01e01.episode.name.nfo
----->Show.Name.s01e02.episode.name.mkv
----->Show.Name.s01e02.episode.name.tbn
----->Show.Name.s01e02.episode.name.nfo
<advancedsettings>
<tvshowmatching>
<regexp>Season[\._ ]([0-9]+)[\\/]([0-9]+)[^\\/]*</regexp>
</tvshowmatching>
</advancedsettings>
- Is my file structure ok for my TV Shows?
- If the bug on github is applicable, should I make my NFS mounts via fstab?
- If so, can someone point me in the right direction?
- Is there something else I should be doing?
~Whip
