Full Version: XBMCbuntu Black Screen Every 10 Minutes
Recently, When watching any movie, etc, on my xmbcbuntu setup, approximately every 10 minutes the screen with go black as if the pc has a power setting or screen saver kicking in.
Yet I can't find where in either xbmc or in xbmcbuntu a setting that may be causing it.
Anyone have any thoughts?
You may want to disable DPMS
xset dpms 0 0 0
xset s off
Make sure Your xbmcbuntu powersaving is also off? http://wiki.xbmc.org/index.php?title=Set...wer_saving
Xbmc screesaver settings? http://wiki.xbmc.org/index.php?title=Set...creensaver
uNi
(2012-11-15, 23:10)uNiversal Wrote: [ -> ]You may want to disable DPMS
xset dpms 0 0 0
xset s off
uNi
Thanks for the help. Its not within XBMC that I can see as I had already checked both those setting and power saving is turned off, and screen saver is set for dim.
This is while playing a movie too. Every 10 minutes or so, the screen will go black, and a simple keyboard press will bring it back up.
Where/How do you disable DPMS? I just logged into the machine via ssh but get an error of
Quote:xset: unable to open display ""
Try
export DISPLAY=:0
then try those again have a read here too https://wiki.archlinux.org/index.php/Dis..._Signaling
its has other commands that may be better
like
xset -dpms
xset s off
The above is to disable DPMS as you asked 2nd time thers settings in xorg.conf see the archwiki site.
uNi
