As promised a step by step guide for integrating this skygo.exe with the TVGuide Addon. I have tried to make this as easy a possible and taken as much messing about as possible out but it is still quite long.
All the credit really goes to mjeyre and PlenG who did the original coding without which this wouldn't be possible.
Repo
Repo -
http://xbmc-skygo.googlecode.com/files/r...-1.0.1.zip
Step 1 -
Download and install the repo from above.
Then install Skygo Launcher - go to configuration and enter your login details.
Step 2 - Only Required if you want freeview channels too.
Favourite all TVCatchup V1 channels
Step 3
Install TVGuide Syborg Mod from the above repo.
Step 4
Open TVGuide configuration and select channels - click update channel list
Step 5
Open Configuration again clear cache then download xmltv file
Step 6
Once download has finished - open tvguide and let it load the xmltv file in
Step 7
Open configuration and run the Channel sort & logos
and that is it you now should open tvguide and it should be fully populated.
Updated 25/03/13 - Changed instructions for caching issue.
Updated 26/03/13 - Made some changes to some icons to provide better contrast against the TVGuide background.
Updated 29/03/13 - New Channels added and channel numbers changed - Instructions
http://forum.xbmc.org/showthread.php?tid...pid1381563 (Only required for people who used the setup instructions before 02/04/13)
Updated 02/04/13 - Updated main instructions with the more recent changes - adding instruction to give an epg for sky disney.
Updated 24/04/13 - Updated to new repo instructions
Updated 13/05/13 - Updated with new instruction - TVGuide Syborg Mod - XMLTV file download integration
Please feel free to post any issues.
