Full Version: (UK ONLY)SkyGO Working now in XBMC
Top work fella. Looking forward to the tv guide, will you be integrating freeview on there too?
(2013-04-29, 17:27)syborg Wrote: [ -> ]V1.1.13 pushed for update - fixed Sky Sports F1 & Sky News now in their correct places and working!
Tvguide automatic integration is coming along. Should have something to show soon.
Very new to XBMC, So sorry for basic question. I have installed Addon V1.1.13, My problem is when I select a sky channel from skygo launcher I then get a pop up "open with" window asking my what program I want to use to open file.
What am I doing wrong?
(2013-04-29, 22:04)givecredit Wrote: [ -> ]
No problem. Can you check a coupke of things for me.
In your c:\skygo you should have a skygolauncher.bat file please confirm its been created.
Is the popup a windows file or xbmc popup?
(2013-04-29, 22:07)syborg Wrote: [ -> ][
The skygolauncher.bat file was created and the popup is a windows file.
(2013-04-29, 22:15)givecredit Wrote: [ -> ]
Can you try running the bat file see what happens.
(2013-04-29, 22:19)syborg Wrote: [ -> ]]
When I run the bat file I get the same windows popup window asking what program do I want to open this file with.
When you right on the bat file do you get a 'open with' option?
(2013-04-29, 22:39)syborg Wrote: [ -> ]When you right on the bat file do you get a 'open with' option?
What run you run the file you need to navigate to c:\windows\system32\cmd.exe and select this program as the program the open the file with.
No. just Open, No Open with,
Run the file then when it asks what to open with navigate to cmd.exe and select and click always use this file
(2013-04-29, 22:54)syborg Wrote: [ -> ]Run the file then when it asks what to open with navigate to cmd.exe and select and click always use this file
When I do this it brings me back to a window with prompt c:\skygo>
(It also does not let me click always use this file box)
(2013-04-29, 23:01)givecredit Wrote: [ -> ]
Can you give your details about your system.
Windows version etc
I've been having problems with the new version too.
About 50% of the times I try to launch a channel I get the following message:
Apologies, this item has been interrupted due to an error. Please click play to resume watching. [ t:3142 / c:4110 square bracket] - OK
Also, if I select the Sky Sports News channel, I get Sky News!
(2013-04-29, 23:08)nashmills Wrote: [ -> ]I've been having problems with the new version too.
That error is a sky end error nothing to do with us. They usually resolve themselves after not too long. Ill check the channel lists and push an update.
Here is a troubleshooting guide from sky that might help if the problem persists
http://helpforum.sky.com/t5/Sky-Go/Sky-G...a-p/578602
(2013-04-29, 23:05)syborg Wrote: [ -> ]Can you give your details about your system.
Windows version etc
Window 7 home premium.run on an Acer R3610 64 Bit operating system
update pushed to fix the Sky News & Sky Sports News mixup - V1.1.14
(2013-04-29, 23:15)givecredit Wrote: [ -> ]
Windows version etc
Could you try running the bat from the cmd window
Open run - type cmd
then once open C:\skygo\skygolauncher.bat
and let me know what happens
