2013-07-23, 19:43
(2013-07-23, 19:30)kyrenia Wrote: [ -> ]hi syborg , yep installed from your repo
If you look at the post between myself and lordloque they may help. Changing the paths may help
(2013-07-23, 22:40)kyrenia Wrote: [ -> ]just checked all appears fine - running from c:\ with no white space in path
(2013-07-24, 23:19)kyrenia Wrote: [ -> ]Sorry not so clear -
I am running from C:/ apposed to any other named drives eg H:\ , all paths listed on post with lordloque appear to be correct for my system.
Location of my skygo.exe is as per the repo install,
c:\users\xbmclounge\appdata\XBMC\addons\plugin.program.skygo.launcher\skygo.exe
skygolauncher.bat works fine if run outside of xbmc with xbmc not running.
With xbmc open but not active ,running skygolauncher.bat from windows, connection to sky will not complete. As soon as i close xbmc the connection to sky will be made and the channel starts.
if I replace the skygo.exe from the repo with the skygo.exe from 1.6 the problem disappears and connection to sky will be made even with xbmc running.
In testing I have used a clean install of xbmc frodo with absolute no addons enabled ( including skygolauncher), I then manually placed the files from the repo direct into the c:\
(modified with user name and password). Running this skygo.exe from windows will connect fine. but open xbmc and any attempts to run the skygo.exe will fail to connect.
(I feel something in skygo.exe 1.7 is hanging when xbmc is running.
Something i did notice is that when skygo.exe 1.6 is ran the "connecting to sky page" is in a window which then switches to full screen once silverlight starts.
Running the repo skygo.exe starts with the "connecting to sky page" full screen .
Might be something in nothing )
clear as mud me thinks.
thanks for the support
cheers
kyrenia
(2013-06-21, 11:46)syborg Wrote: [ -> ](2013-06-21, 09:23)BigTaff Wrote: [ -> ]Already finished, did that before posting on here to see if that was an obvious fix (it wasn't, lol).
Here is what you need to change
This is assuming that everything else is default except that your main drive is H: instead of C:
You need to go into H:\Users\[your username]\appdata\roaming\xbmc\addons\plugin.program.skygo.launcher\
Edit the following files
movingfile.py
line 5 - 'C:\\Skygo' to 'H:\\Skygo'
line 9 - "c:\skygolauncher.bat" to "h:\skygolauncher.bat"
line 10 - os.path.expanduser(r'~\AppData\Roaming\XBMC\addons\plugin.program.skygo.launcher\resources\skygolauncher.bat') to "H:\Users\[your username]\AppData\Roaming\XBMC\addons\plugin.program.skygo.launcher\resources\skygolauncher.bat"
line 15 - 'c:\\skygo\\' to 'h:\\skygo\\'
settings.py
line 11 - os.path.expanduser(r'~\AppData\Roaming\XBMC\addons\plugin.program.skygo.launcher\skygo.cfg') to "H:\Users\[your username]\AppData\Roaming\XBMC\addons\plugin.program.skygo.launcher\skygo.cfg"
and the launchers file which you have already edited yourself.
If you are wanting to use the TVGuide mod too there will be more to edit but try this and get back to me whether this works.
(2013-07-30, 12:45)Pavle Wrote: [ -> ](2013-06-21, 11:46)syborg Wrote: [ -> ](2013-06-21, 09:23)BigTaff Wrote: [ -> ]Already finished, did that before posting on here to see if that was an obvious fix (it wasn't, lol).
movingfile.py
settings.py
What would i need to edit in order to use the TVGuide mod?
(2013-07-30, 14:32)Pam55ela Wrote: [ -> ]I dont have the programming ability but would to test anything and give feedback.There's a working version for most people the editing is only required if you installed Xbmc in a non standard directory.
(2013-08-01, 18:53)winterriots Wrote: [ -> ]Hi,
Thanks for the addon, great work!
I have a problem though - every channel I seem to select starts up Sky One. Any help is much appreciated!
(2013-08-01, 18:56)winterriots Wrote: [ -> ]Yes - I downloaded the repo addon and the files from SkyDrive as instructed in the first post.
I've checked the SkyGoLauncher.bat file and the correct channel number is being passed to skygo.exe.
