2013-08-12, 11:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
2013-08-12, 14:22
(2013-08-12, 10:47)syborg Wrote: [ -> ]Are you using skygolauncher addon from my repo or are you using the skydrive files?
Hi Syborg. I did download your skygolauncher addon but couldn't understand what to do with it, so I downloaded the skydrive files, moved them to their own folder in the C:\ drive and ran skygocache.bat
2013-08-12, 14:54
(2013-08-12, 14:22)tomcon Wrote: [ -> ](2013-08-12, 10:47)syborg Wrote: [ -> ]Are you using skygolauncher addon from my repo or are you using the skydrive files?
For the launcher all you have to do is add your username and password in the setting then select your channel done.
The skydrive files aren't really supported anymore.
2013-08-14, 00:32
Tried with the skygolauncher addon but it's coming up with the same error. Any ideas?
2013-08-14, 00:35
(2013-08-14, 00:32)tomcon Wrote: [ -> ]Tried with the skygolauncher addon but it's coming up with the same error. Any ideas?
Is this error coming up in xbmc or is it a windows error. Did you remove all the sky drive files before installing the addon?
2013-08-14, 13:10
I am very interested in getting skygo working on xbmc but i am using a Macbook pro, can you talk me through doing it on here and what folders i should be putting it the files in as its a different structure than a windows based system.
Thanks guys
Thanks guys
2013-08-14, 13:12
(2013-08-14, 13:10)nuera19 Wrote: [ -> ]Hi,
Thanks guys
There is no way at the moment for this to work on the mac maybe in future
2013-08-14, 13:30
(2013-08-14, 13:12)syborg Wrote: [ -> ](2013-08-14, 13:10)nuera19 Wrote: [ -> ]Hi,
Thanks guys
Boo! ok well i will just have to be patient, is that the same for xbmc on Apple TV?
2013-08-14, 23:34
(2013-08-12, 14:54)syborg Wrote: [ -> ](2013-08-12, 14:22)tomcon Wrote: [ -> ](2013-08-12, 10:47)syborg Wrote: [ -> ]Are you using skygolauncher addon from my repo or are you using the skydrive files?
(2013-08-14, 00:35)syborg Wrote: [ -> ](2013-08-14, 00:32)tomcon Wrote: [ -> ]Tried with the skygolauncher addon but it's coming up with the same error. Any ideas?
This is the error which comes up...
I didn't remove the sky drive files before installing the addon. Should I do a reinstall of XBMC?
2013-08-17, 11:37
So I've tried doing a fresh install of XBMC but still seem to be having the same issue. The same script error (posted above) comes up the first time I select a channel, and if I press 'no' then the channel seems to load fine. But then when I go back to select a different channel, a different script error comes up...
And then another script error comes up...
It then stays on the loading player screen but doesn't actually load anything.
Does anyone have any ideas?
2013-08-17, 20:37
hi , im seeing a similar issue. was working fine but as of last Monday, now sits at loading player after a few minutes i get same pop up window with error
2013-08-17, 21:53
This error a sky side error some people get it some don't haven't been able to pin down why exactly it
2013-08-18, 16:55
Hello
Sorry if this is not the right place, but I have downloaded the repo and entered the sky account login details.
Although now when I try to launch it I get a window asking which programme I want to open with, then nothing happens.
I apologise if this something simple but am not that much of a techie.
Thank you for looking
Vicci
Vicci
2013-08-18, 17:05
(2013-08-14, 23:34)tomcon Wrote: [ -> ](2013-08-12, 14:54)syborg Wrote: [ -> ](2013-08-12, 14:22)tomcon Wrote: [ -> ]Hi Syborg. I did download your skygolauncher addon but couldn't understand what to do with it, so I downloaded the skydrive files, moved them to their own folder in the C:\ drive and ran skygocache.bat
Hi there I have the same issue as this. I am using windows 7 with all updates as of today, the latest versions of IE 9 and Silverlight. My sky go account is sky go extra - not sure if any of this helps....
I initially tried running the launcher without the username/password and have since uninstalled xbmc and reinstalled it with no success.
Is it possible to use a different browser?
Many thanks Syborg for all your work on this.
2013-08-19, 12:25
(2013-08-18, 17:05)xbmcsteve Wrote: [ -> ](2013-08-14, 23:34)tomcon Wrote: [ -> ](2013-08-12, 14:54)syborg Wrote: [ -> ]For the launcher all you have to do is add your username and password in the setting then select your channel done.
(2013-08-14, 00:35)syborg Wrote: [ -> ]Is this error coming up in xbmc or is it a windows error. Did you remove all the sky drive files before installing the addon?
+1 on this issue. Been having this problem since day one, otherwise all is fine mostly. A solution would be great.
