(2014-02-26, 00:21)GrantXP Wrote: [ -> ]Good news, I launched it but each time it goes to the Sky login page? Any ideas?
Can you give me more information on your setup. IE version etc.
Does it enter your username and password or just leave it blank?
Hi Syborg, appreciate the response. The first time I set it up it was blank. I then populated it and selected remember my password. Each time I launched it after that it was populated but didn't login.
I am using IE 10, XBMC 12 (Frodo), I only breifly tried this. I'll restart everything and try again this evening.
Upgrading to IE11 fixed th0msk issues try that I'm working on a fix now for the channel info is will have a look to see what I can do to make the login more robust!
Update push to the repo - just now. Should fix the channel info issue (its not very elegant but it works). The login should be more robust now too as it waits for everything to load before trying to add in the username and password. You can adjust the length of the time between the step of the program in the setting now. If you experience problems increase the time - alternatively if you want you can try speed thing up the login process you can decrease the time.
I also fixed the focus issue on my windows 7 box - everything still worked on my Win8 box too so I don't think I've broken anything by doing so but if I have let me know.
Hi Syborg,
I have updated from the repo via the XMBC menu, but I'm getting the following error now:
Is the skygov2.exe missing from the Repo?
What's the version number?
Just refreshed from the Repo again and version is 1.3.0... and it's working now without the channel info being displayed
... I'm pretty sure it was version 1.2.3 that I picked up from the Repo earlier so looks like I had a problem with my refresh!
I'll give this version a good workout and let you know how it goes, but first impressions are good.
Thanks a lot for the effort!
Great to see your supporting this addon again. Will give it a try again later. Hopefully now I can get it to work on my 64bit windows 7 pc. Failed the last time i tried.
Today is a good day to try. Will move my sky go to pc from tablet. If it fails I can always switch back to tablet on saturday, March 1st.
On a personal note. Hope your House move worked out well.... [/i]
Ok, updated addon to 130. Now working on my media pc. Only problem I have is your Info Bar fix does not work for me. The Mouse move to top of screen happens too early. My info bar appears after the mouse movement.
(2014-02-28, 15:04)givecredit Wrote: [ -> ]Ok, updated addon to 130. Now working on my media pc. Only problem I have is your Info Bar fix does not work for me. The Mouse move to top of screen happens too early. My info bar appears after the mouse movement.
In the settings increase the length of time for the second sleep setting.
(2014-02-28, 15:05)syborg Wrote: [ -> ] (2014-02-28, 15:04)givecredit Wrote: [ -> ]Ok, updated addon to 130. Now working on my media pc. Only problem I have is your Info Bar fix does not work for me. The Mouse move to top of screen happens too early. My info bar appears after the mouse movement.
That done the trick. Thanks.
Just started to try and use this and I think the concept is great. Having real issues setting it up though :-P
Tried using Chrome and IE 11 on Windows 8.1 x64 and I get the following everytime:
Even though its the latest version installed.
I also get this:
Log file says this:
Quote:Traceback (most recent call last):
File "skygov2.py", line 180, in <module>
File "skygov2.py", line 120, in channel_selector
File "skygov2.py", line 135, in channel_launcher
File "win32com\client\dynamic.pyc", line 511, in __getattr__
pywintypes.com_error: (-2147352567, 'Exception occurred.', (0, None, None, None, 0, -2146827850), None)
C:\Users\lewisj\AppData\Roaming\XBMC\addons\plugin.program.skygo.launcher\skygov2.exe\pyHook\HookManager.py:349: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
File "pyHook\HookManager.pyc", line 349, in KeyboardSwitch
TypeError: an integer is required
File "skygov2.py", line 132, in channel_launcher
File "win32com\client\dynamic.pyc", line 522, in __getattr__
AttributeError: <unknown>.signinform
File "skygov2.py", line 117, in channel_selector
Exception TypeError: 'an integer is required' in 'garbage collection' ignored
File "skygov2.py", line 144, in channel_launcher
ValueError: Point out of bounds
File "skygov2.py", line 28, in <module>
File "urllib2.pyc", line 126, in urlopen
File "urllib2.pyc", line 391, in open
File "urllib2.pyc", line 409, in _open
File "urllib2.pyc", line 369, in _call_chain
File "urllib2.pyc", line 1173, in http_open
File "urllib2.pyc", line 1148, in do_open
urllib2.URLError: <urlopen error [Errno 11001] getaddrinfo failed>
File "skygov2.py", line 124, in channel_launcher
File "win32com\client\__init__.pyc", line 95, in Dispatch
File "win32com\client\dynamic.pyc", line 114, in _GetGoodDispatchAndUserName
File "win32com\client\dynamic.pyc", line 91, in _GetGoodDispatch
pywintypes.com_error: (-2147221005, 'Invalid class string', None, None)
Can anyone point me in the right direction?
Cheers
(2014-03-04, 19:32)liquidtoon Wrote: [ -> ]Just started to try and use this and I think the concept is great. Having real issues setting it up though :-P
I also get this:
Log file says this:
Cheers
Ok it only works with internet explorer. If your getting issues with silverlight get that working independently of the addon.
Open ie and install silverlight. Restart ie then go to skygo through the website and play a channel manually. If this works then close ie and restart xbmc. Now try again.
Ah great, working now. just took a uninstall and reinstall of Silverlight. Cheers
Me again
Loads the channel fine but the pop up alert still shows asking to view the log file:
Once the channel has loaded controls no longer work (5, Enter, Esc). Any thoughts on how I can sort this out? I'll be laughing after this. Cheers.
There shouldn't any controls except backspace which will take you back to xbmc. I'll have a look at adding controls but I don't know how feasible this will be tbh. There are no keyboard shortcuts for skygo so it will mean using a mouse moves and clicks so it might be a bit clunky but when I'm back from my trip I'll give it a shot.
Can you delete the log file then run again and send me the new log file and I'll be able to see better what causing the problem.
