2012-11-16, 10:43
In the wiki it says that thumbnail for folder art should re-cache if the checksum is different but I find this not to be the case. I spend a lot of time organising my album artwork and often update to higher resolution covers and the only way to get them active is to delete the thumbnails folder and, now with Frodo, delete the textures.db file.
I have tried refreshing manually using the album information menu on the folder but this is really cumbersome and doesn't work quickly or efficiently, often taking a minute or two to get to the thumbnail menu and fiddling around until the art finally recaches. Which is a no-go when you have a whole bunch to update (easier deleting the files and restarting.)
