Hello,
I'm going to build system for xbmc and wanted to ask you about hardware choice, firstly I'm going to use xbmc linux or windows, It really doesn't matter which OS, and I want to use xbmc for 1080p videos and also I have lg 3d tv and want to watch some 3d movies also and some web based flash or html5 videos like youtube and streaming websites. Also I need optical 5.1 output support.
will this hardware be enough for all the things I want ?
mobo : gigabyte mini itx GA-H61N-USB3
cpu: Intel PENTIUM G860 3.0GHZ 1155PİN 3MB VGA850 BOX or Sandy Bridge Pentium G630, their price is close to each other.
ram; 4gb DDR3 ram
hdd :60gb sandisk ssd hdd
I will build case myself and what kind of power supply I need ?
thanks in advance
For 3D support you will need an Intel i3 CPU. Alternatively there are the AMD Llano or Trinity APU's, I recommend one of the A6 variants as a minimum, but you will have to also change the motherboard.
David
(2012-11-16, 12:40)DavidT99 Wrote: [ -> ]For 3D support you will need an Intel i3 CPU. Alternatively there are the AMD Llano or Trinity APU's, I recommend one of the A6 variants as a minimum, but you will have to also change the motherboard.
David
will it be possible to use with graphics card such as ZOTAC GF210 Synergy GDDR3 1GB 64Bit fanless or ASUS GT610 SILENT GDDR3 1GB 64BIT
or ZOTAC GT430 SYNERGY GDDR3 1GB 128BIT
(2012-11-16, 13:18)eCCoMaNia Wrote: [ -> ] (2012-11-16, 12:40)DavidT99 Wrote: [ -> ]For 3D support you will need an Intel i3 CPU. Alternatively there are the AMD Llano or Trinity APU's, I recommend one of the A6 variants as a minimum, but you will have to also change the motherboard.
David
For 3d, these might the cheapest newest all-in-one CPU's-
Intel i3-3220 and
AMD A6-5400K......for PSU, I'm recommending this fanless "
picoPSU-120/10A 120W AC-DC" for it....
(2012-11-16, 16:48)bluray Wrote: [ -> ] (2012-11-16, 13:18)eCCoMaNia Wrote: [ -> ] (2012-11-16, 12:40)DavidT99 Wrote: [ -> ]For 3D support you will need an Intel i3 CPU. Alternatively there are the AMD Llano or Trinity APU's, I recommend one of the A6 variants as a minimum, but you will have to also change the motherboard.
David
or ZOTAC GT430 SYNERGY GDDR3 1GB 128BIT+
For 3d, these might the cheapest newest all-in-one CPU's- Intel i3-3220 and AMD A6-5400K......for PSU, I'm recommending this fanless "picoPSU-120/10A 120W AC-DC" for it....
I agree with bluray, but would prefer 3220t over a 3220 in a mini itx build.
David
For i3 3220 do i need to buy graphics card or integrated graphics will be enough ??
(2012-11-16, 18:58)eCCoMaNia Wrote: [ -> ]For i3 3220 do i need to buy graphics card or integrated graphics will be enough ??
No, HD2500 iGPU in it is more than enough for HTPC.....
(2012-11-17, 03:51)bluray Wrote: [ -> ] (2012-11-16, 18:58)eCCoMaNia Wrote: [ -> ]For i3 3220 do i need to buy graphics card or integrated graphics will be enough ??
Good, thanks for your help bluray...
David
I can get i3 3225 now for same price and what do you think ? is it worth to change it ?
