2012-11-16, 16:16
Pages: 1 2
2012-11-17, 03:56
What DBID on home?
2012-11-17, 05:09
Well... It seems that i can do for example, this for tvshows, but not for movies.
From what i understood from Martijn is that that is because $INFO[ListItem.DBID] is empty on Home.
But then it seems, that is only the case for movies.
So i wondered if this had a reason.
<onload>RunScript(script.artwork.downloader,mode=custom,dbid=$INFO[ListItem.DBID],mediatype=tvshow,clearlogo)</onload>
2012-11-17, 05:36
Because you have no listitem ?
2012-11-17, 06:42
I have both recent movie and tvshow on home in 2 separate panels.
Then why would tvshow have a listitem and movies not?
2012-11-17, 07:15
Recently added on home (as in built-in stuff) doesn't set this for either type.
2012-11-17, 07:26
I'm using widgets. With their own content. So it should have a listitem.
And i can pull the logo for tv shows in an image control.
<content>
<item>
<label>$INFO[Window(Home).Property(RecentMovie.1.Title)]</label>
<property name="Logo">$INFO[Window(Home).Property(RecentMovie.1.Art(clearlogo))]</property>
</item>
<item>
<label>$INFO[Window(Home).Property(RecentMovie.2.Title)]</label>
<property name="Logo">$INFO[Window(Home).Property(RecentMovie.2.Art(clearlogo))]</property>
</item>
</content>
$INFO[Container(8001).ListItem.Property(Logo)]
2012-11-17, 07:44
I would think it would be up to the script supplying said widget I would think?
2012-11-17, 08:07
Alright. Well thnx, as always
I'll go see if i can find my answer there.
2012-11-17, 16:14
you should at least pass the container id to the script as well...
but before going any further...what is it exactly you're trying to do?
2012-11-17, 16:16
(2012-11-17, 16:14)ronie Wrote: [ -> ]you should at least pass the container id to the script as well...
He wants to call artwork downloader from home screen so you need DBID
2012-11-17, 20:19
What i want to do is the following:
I am including the following 2 panels on home (recent tv and recent movies). With widgets, so they have content and listitem. And this works fine for both.
http://pastebin.com/g2Hy5dGF
Next to the panels i want (instead of the tvshow / movie title) to show the clearlogo. And i can only get this to work for tvshows.
I use the following, to run AD and DL the logos for tv shows:
This works fine. And yes if i want to do this for 2 containers i have to add the container ids.
For testing i was only including the movie widget, but even then (with or without container id) i can't get it to download the logos.
Using the same <onload> except with "tvshow" replaced by "movie".
It gives an error because , "movieid": } does not have a number specified.
Apparently because DBID is only available for tvshows on home. And not for movies.
So i thought this was something to do with the core and i asked what the reason was for it being only available for tvshows. But if i understand correctly now this has nothing to do with the core, and is because it is not available in the widget.
So again, if i understand correctly, i have to ask Martijn if he can also make this available for movies.
And / or why this is only available for tvshows? As i thought it might have had a reason i was not aware of.
2012-11-18, 00:47
Have you tried using Container(id).ListItem.dbid ?
It has nothing at all to do with it being at home. If anything, it has to do with there being 2 lists OR with whatever is filling those containers not providing the db id in the first place.
2012-11-18, 00:53
I didn't set any id in the script so why one would work and the other doesn't is beyond me
2012-11-18, 01:07
are you sure this currently works for tv shows MassIV?
i can think of at least three reason why this can never work at all:
- as Martijn said, skin widgets doesn't even provide a dbid
- on window load, the lists are still empty, so you can't pass a listitem to the script as there are none
- you've probably got multiple containers on home, this can be widget panels, but also your main menu and/or submenus,
so you'll always need to pass a container id to the script.
Pages: 1 2
