When I upgraded from Frodo to Gotham I thought I would give the pulse audio server a try and I am having some issues I would like to get some feedback on.
First a little system background:
PC - Zotac Nano ID61
OS - Ubuntu 14.04 LTS with all latest updates
Receiver - Onkyo TX-NR737
I have a 7.1 Channel setup in my primary zone and a zone2 stereo setup. The onkyo receiver only allows analog sources for zone2.
On Frodo I was running the alsa configuration from this thread with no issues. In my main room I could achieve 7.1 channel PCM or Passthrough from any video source through the HDMI to the receiver. I could also enable zone 2 and get 5.1 audio in the main room and 2 channel stereo from the 3.5mm jack on the PC which allowed me to output the same audio in both rooms.
Upon upgrading and trying the Pulse audio server I have been able to enable both zones as described in the new audio wiki. One note here is that I was only able to get the second zone working by adding the following to my /etc/pulse/default.pa file:
### Load analog device
load-module module-alsa-sink device=hw:0,0
load-module module-combine-sink sink_name=combined
set-default-sink combined
I couldn't just add "load-module module-combine-sink sink_name=combined" to the file and achieve dual output.
I was then able to get dual audio working using the multichannel setup from the audio wiki. I did not like how Pulse audio re-sampled multchannel video sources. It put way too much voice in the rear channels. So I decided to go with the passthrough option from the audio wiki.
This is where I am now having a problem. It seems I can either get passthrough or dual audio to work and not both. When I get dual audio working I can output music to all speakers in both zones but I get no audio from any movies that have multichannel audio. Conversely if I get passthrough working i lose the ability to output from both the HDMI and the 3.5mm jack simultaniously.
I have followed all the instructions in the audio wiki (
http://wiki.xbmc.org/index.php?title=PulseAudio ) with the only exception of the additional lines in the default.pa file outlined above.
I may just default back to my alsa configuration, but it would be nice to get pulse audio working so I could broadcast music to other rooms via my network.
Anyone have any ideas?
