Full Version: XBMCBuntu Frodo RC - AE: Error - no devices found
Pages: 1 2 3 4 5 6 7 8 9
Under Settings/System/Audio output it says "Error - no devices found" for Audio output device and Pasthrough output device.
I'm using an optical audio connection on a AT5IONT-I mobo. (Nvidia)
Debug log: http://pastebin.com/Fsp2DX0i
[email protected]:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
default:CARD=Intel
    HDA Intel, ALC887 Analog
    Default Audio Device
sysdefault:CARD=Intel
front:CARD=Intel,DEV=0
    Front speakers
surround40:CARD=Intel,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
    HDA Intel, ALC887 Digital
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Intel,DEV=0
    Direct sample mixing device
dmix:CARD=Intel,DEV=1
dsnoop:CARD=Intel,DEV=0
    Direct sample snooping device
dsnoop:CARD=Intel,DEV=1
hw:CARD=Intel,DEV=0
    Direct hardware device without any conversions
hw:CARD=Intel,DEV=1
plughw:CARD=Intel,DEV=0
    Hardware device with all software conversions
plughw:CARD=Intel,DEV=1
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
Update
Audio works booting XBMC from the installation USB flash drive with AVR turned on.
Audio works first boot after fresh install with AVR turned on, after a reboot (AVR still turned on) audio is gone and "Error - no devices found" in audio output settings.
Update 2
This issue seems to be related to using an SSD see page 7,8.
(2012-11-28, 02:48)Quiptix Wrote: [ -> ]I have this problem since I added a SSD to the HTPC.
Based on previous solution a have added a sleep 10 in /etc/init/lightdm.conf just before the actual start of lightdm.
The audio subsystem is not initialized yet without this wait which yields in not finding any audio devices.
Somehow there needs to be soms check that (all) sound systems are intialized or you need to make sure lightdm is the absolute last process to boot.
Vincent
Related tickets:
http://trac.xbmc.org/ticket/13703
http://trac.xbmc.org/ticket/13578
I would bet a handful of pubic hair, that this is a permissions issue (since I experienced this myself) Though yours its xbmcbuntu and probably wacked, again.
User groups permissions http://forum.xbmc.org/showthread.php?tid...pid1217997
Though obvious make sure its the username running xbmc, in my case the username is xbmc to make things "simpler"
In the event I just lost a bet there's also a bug ad a PR for something like this. https://github.com/xbmc/xbmc/pull/1779
whoopla +1
uNi
this is probably a know issue: https://github.com/xbmc/xbmc/pull/1779
if you happen to be able to compile yourself, please try with this patch applied and report back.
uNi usermod didn't fix it.
wsnipex I'll try to compile it and report back.
When you report back can I have the result of
id $USER
Make sure you run that in your username and not under root in case.
uNi
(2012-11-17, 19:49)uNiversal Wrote: [ -> ]When you report back can I have the result of
id $USER
uid=1000(xbmc) gid=1000(xbmc) groups=1000(xbmc),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),104(fuse)
add your xbmc to users it needs users, see the link I gave you
see mine gid=1000(xbmc) groups=1000(xbmc),4(adm),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),100(users),104(fuse)
uNi
(2012-11-17, 20:28)uNiversal Wrote: [ -> ]add your xbmc to users it needs users, see the link I gave you
uNi
[email protected]:~/xbmc$ sudo adduser xbmc users
The user `xbmc' is already a member of `users'.
Not according to you id $USER result :/
uNI
(2012-11-17, 20:43)uNiversal Wrote: [ -> ]Not according to you id $USER result :/
uNI
I know it is really weird. I'm compiling with the patch right now, but I'm wondering if "sudo make install" will replace xbmc on XBMCBuntu because I think the binary on XBMCBuntu is called xbmc-standalone?
[email protected]:~$ whereis -b xbmc
xbmc: /usr/bin/xbmc /etc/xbmc /usr/lib/xbmc /usr/bin/X11/xbmc /usr/share/xbmc
[email protected]:~$ whereis -b xbmc-standalone
xbmc-standalone: /usr/bin/xbmc-standalone /usr/bin/X11/xbmc-standalone
(2012-11-17, 17:56)wsnipex Wrote: [ -> ]this is probably a know issue: https://github.com/xbmc/xbmc/pull/1779
Tried hard. Failed to compile.
Uppdate
XBMC built successfully
Patch is working, because the error is gone and I can select a few output devices.
Sadly I cannot get any sound. I tried all the output devices and I'm sure that my receiver is capable of DTS/AC3 (worked perfectly in Eden btw).
Try removing any asound.conf or .asoundrc you may have.
uNI
(2012-11-17, 23:29)uNiversal Wrote: [ -> ]Try removing any asound.conf or .asoundrc you may have.
uNI
Removed both files and now I'm back to Error no devices Tongue
(2012-11-17, 23:40)uNiversal Wrote: [ -> ]try this asound http://forum.xbmc.org/showthread.php?tid=145430
uNi
Same error.
null
pulse
default:CARD=Intel
    Front speakers
hw:CARD=Intel,DEV=0
hw:CARD=Intel,DEV=1
    HDA NVidia, HDMI 0
    HDMI Audio Output
    HDA NVidia, HDMI 0
    HDA NVidia, HDMI 0
    HDA NVidia, HDMI 0
    HDA NVidia, HDMI 0
