Full Version: Running Skygo exe file from main menu
I have created a .exe file that can automatically run the skygo website and skygo. Please could anyone tell me how to get this in the main menu w an icon.
M
anyone help put skygo on my front screen please ? eden 11
cheers
mike
You can try using the Advanced Launcher add-on to run your executable, then create a favourite for that launcher and, if your skin supports it, create a main menu shortcut to run that favourite.
how do i create a favorite, ive done the advanced launcher bit ages ago.
cheers
xbmcmike
(2012-12-13, 17:41)mjeyre Wrote: [ -> ]how do i create a favorite, ive done the advanced launcher bit ages ago.
cheers
xbmcmike
Select the launcher, press the "C" key and select the "Add to Favourites" option. Then from the skin settings, add link this favourite as a menu or submane entry.
thanks !
xbmcmike
