I have a folder.jpg in a lot of folders that have TV shows. These Wide Icons have been in use for a few years but now after I updated to Frodo Beta 1 they donĀ“t appear at all.
Any ideas why these icons have disappeared ?
Note that folder.jpg will work just fine still (as the link above suggests).
You will have been prompted that your art needed updating, and that would have dropped your folder.jpg into the "banner" slot of each tvshow.
Bah, disregard original post. A sunday night hangover is not the time to be troubleshooting.
I had the system on some ConfluenceMOD skin which broke with the update. Switched to the orginal Confluence skin and everything works like a charm.
So the issue is not with XBMC but with the skin.
Thanks for the prompt reply guys and your amazing work as always.
