Full Version: Scraping errors IMDB
Hello,
i have a bit of akward problem.
I recently installed fresh install of Eden, enabled IMDB and set it as default straper with option to DL movie name in my native language (Croatian).
80 % of my movies are scraped correctly, but some titles are not, as Prometheus, 2012 (2009), The Bounty Hunter (2010)... so not some unknown movies.
When I try to update movie info, it doesen't even show the movie in found enteries, like it's not on IMDB.
I have to say that i installed XBMC on multiple PC so far and never had this kind of problems.
LOG:
18:43:30 T:3392 DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
18:43:30 T:3392 DEBUG: CApplication::ExecuteXBMCAction : Translating CancelAlarm(ActorIconMove,true)
18:43:30 T:3392 DEBUG: CApplication::ExecuteXBMCAction : To CancelAlarm(ActorIconMove,true)
18:43:30 T:3392 DEBUG: CApplication::ExecuteXBMCAction : Translating ClearProperty(FanartZoom,movieinformation)
18:43:30 T:3392 DEBUG: CApplication::ExecuteXBMCAction : To ClearProperty(FanartZoom,movieinformation)
18:43:30 T:3392 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'D:\Filmovi\The Bounty Hunter (2010) BluRay\The Bounty Hunter (2010).mkv'
18:43:30 T:3392 INFO: Loading skin file: DialogProgress.xml
18:43:30 T:3392 DEBUG: DialogProgress::StartModal called
18:43:30 T:3392 DEBUG: ------ Window Init (DialogProgress.xml) ------
18:43:30 T:3392 DEBUG: HttpApi Start command: GetCurrentlyPlaying paras: GetCurrentlyPlaying
18:43:31 T:116 DEBUG: Thread CVideoInfoDownloader start, auto delete: 0
18:43:31 T:116 DEBUG: ADDON::CScraper::FindMovie: Searching for 'The Bounty Hunter' using IMDb scraper
(path: 'C:\Users\Tomislav\AppData\Roaming\XBMC\addons\metadata.imdb.com', content: 'movies', version: '2.6.1')
18:43:31 T:116 DEBUG: scraper: CreateSearchUrl returned <url>http://akas.imdb.com/find?s=tt;q=the%20bounty%20hunter%20(2010)</url>
18:43:31 T:116 DEBUG: FileCurl::Open(0046DC88) http://akas.imdb.com/find?s=tt;q=the%20b...r%20(2010)
18:43:31 T:116 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://akas.imdb.com
18:43:31 T:3392 DEBUG: HttpApi Start command: GetCurrentlyPlaying paras: GetCurrentlyPlaying
18:43:35 T:116 DEBUG: Previous line repeats 8 times.
18:43:35 T:116 DEBUG: scraper: GetSearchResults returned <?xml version="1.0"
encoding="iso-8859-1" standalone="yes"?><results><entity><title>Star Wars: The Clone Wars</title><year>2008</year>
<url cache="tt0458290-main.html">http://akas.imdb.com/title/tt0458290/</url><id>tt0458290</id>
</entity><entity><title>The Bounty Hunter</title><year>1954</year><url cache="
tt0046801-main.html">http://akas.imdb.com/title/tt0046801
(That's not the whole log, I just put the things I found interesting).
Please help Smile
Thnx.
And we want the whole log
(2012-11-19, 21:48)Martijn Wrote: [ -> ]And we want the whole log
Here it is. Thnx. Log
(2012-11-19, 21:08)TomislavV Wrote: [ -> ]Prometheus, 2012 (2009), The Bounty Hunter (2010)
All three of these have multiple films in the same year with the same title on IMDB. e.g. 2012 (2009/I) and 2012 (2009/II).
Not that I have a solution to the problem, just that's probably where the issue lies...
Ist it possible, that IMDB themselves are modifying existing movies? i have a non automatically updated movie list, where all movies are correctly matched to IMDB. No i discovered on IMDB that in certain Movies a (I) has bee put back in the name.
With Prometheus (2012), Mirror Mirror (2012) i have now the same issues - and it's not all - but one weeke ago, everything was fine.
I named all my movies exactly after the IMDB.com Naming, to ensure a proper result.
Should we just wait until it's fixed (scraper issue) or do we have to accept, that the IMDB DB can be modified to whatever the are happy to do?
thx a lot for your work...
