Full Version: How the heck is this been scraped??
C:\Windows\System32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\c2.bin
This is the file that is showing up in my movie library and is been scraped as the movie "Infested" and it shows up numerous times. If I remove from library, it doesn't remove the file(s)
Another is scraped from C:\windows\mib.bin and showing up as the movie titled "Slave Window"
This is another directory
C:\Windows\winsxs\amd64_microsoft-windows-snmp-mgmt-api_31bf3856ad364e35_6.1.7600.16385_none_47815118cd38388a
This also has the same file mib.bin
Why are these files been scraped when the directories and not in the scraped listHuh?
Because you managed to "set content" on C:\ most likely. Check the path table of your database.
(2012-11-20, 00:22)jmarshall Wrote: [ -> ]Because you managed to "set content" on C:\ most likely. Check the path table of your database.
I am running MYSQL in my WHS. How do I query the database and what am I looking for.
Not sure if I mentioned it, but I am not able to remove these files.
I don't want to delete the actual files.
