2012-11-21, 20:33
Pages: 1 2
2012-11-21, 22:40
(2012-11-21, 18:35)SolidSkin Wrote: [ -> ]Solved.If all the hardwares support HD audio and you do as I suggested in post #11, there is no reason that it wouldn't work......I'm glad that you got it to work now....
When I plugged the HTPC into the Pioneer LX-82 amp. Then there was an extra icon within the audio area listed as Pioneer LX82.
It then showed all the supported formats, DTS-HD and the rest are listed
This is also listed as been part of the Intel HD audio.
Thanks for your help all !!
2012-11-22, 01:48
Thank you very much much appreciated!!!!!
Really happy it's working.
(2012-11-21, 22:40)bluray Wrote: [ -> ](2012-11-21, 18:35)SolidSkin Wrote: [ -> ]Solved.If all the hardwares support HD audio and you do as I suggested in post #11, there is no reason that it wouldn't work......I'm glad that you got it to work now....
2012-11-22, 02:03
a. Download- HDAudio + Eden RC2
Is it worth while installing this?
I did not install it
2012-11-22, 03:04
(2012-11-22, 02:03)SolidSkin Wrote: [ -> ]a. Download- HDAudio + Eden RC2Yes, bitstreaming HD audio have been working great for me so far.....
2012-11-22, 09:52
(2012-11-22, 02:03)SolidSkin Wrote: [ -> ]a. Download- HDAudio + Eden RC2Why - if HD Audio is working with the build you have. This is an old unsupported build and there is nothing to be gained by installing it. What build are you using at the moment?
2012-11-22, 17:53
Would I be able to link my HTPC up as follows...
DVI (converter to HDMI) to my Panasonic TV for watching normal TV channels etc.
HDMI out to my AV receiver for watching films?
This this work without hassle or will there need to be manual switching?
Pages: 1 2
