hello,
After having to install and configure the new version of XBMC Eden yesterday all work perfectly.
This morning I wanted to test you again works well before placing them properly in its place.
I have no sound and no movies that starts as if the player crash.
I try everything I can not find the solution thank you for your help
xbmc.log
xbmc.old.log
I'm logged in root user and xbmc play movies but the sound out in ma sound carte of my PC not in HDMI
Quik info => I remember this problem occured when I use " xbmc audio mixer " and now when I launch xbmc audio mixer is empty
Open terminal and type alsamixer if this works unmute your devices in there
uNi
thanks for your reply but I have problem with alsamixer
xbmc@xbmc-server:~$ alsamixer
ALSA lib conf.c:1219:(parse_def) default is not a compound
ALSA lib conf.c:1685:(snd_config_load1) _toplevel_:1:13:Invalid argument
ALSA lib conf.c:3467:(snd_config_hook_load) /home/xbmc/.asoundrc may be old or corrupted: consider to remove or fix it
ALSA lib conf.c:3326:(snd_config_hooks_call) function snd_config_hook_load returned error: Invalid argument
ALSA lib conf.c:3713:(snd_config_update_r) hooks failed, removing configuration
cannot open mixer: Invalid argument
there you go
remove the offending file or rename it or fix it.
Your problem should go away.
uNi
(2012-11-20, 17:43)uNiversal Wrote: [ -> ]there you go
ALSA lib conf.c:3467snd_config_hook_load) /home/xbmc/.asoundrc may be old or corrupted: consider to remove or fix it
uNi
Yes I just copy my backup .asoundrc it's ok now
THX Man for your Help
