Full Version: adding/modifying current font to add arabic characters?
hi; i was wondering if there is away to add a font to the this skin that supports arabic characters. the only skin available at the moment with this kinda support is confluence. i was wondering if its possible to do so with Quartz skin, i really like it on my ATV2. and i want to keep using it.
Thank you;
Goto settings/appearance and change font to arial.
Other possibility would be to use your own font but to rename it as the one that is used now and overwrite it - take a look at skin/fonts folder and overwrite the one you like with your own.
Thank you so much, worked by changing it to arial
