Full Version: Intel core I3-2100 screen resolution
I find several How-To but nothing helps.
I try to install XBMCbuntu and that works fine. I connect the system (Dell Optiplex 790 USFF) via Displayport and converter to HDMI to a Denon AVR. All systems are switched ON/OFF with a master switch (without shutdown).
The problem is, if the system is switched on, the xbmc don't see a display and have e resolution from 640x480 or similar. If I start the system after the AVR and Monitor are ON, there is no problem.
I don't find a configuration or setup that starts the system in a fix resolution independent whats at the end of the HDMI.
Have somebody a tip for me?
