2013-08-31, 19:56
Just attempted to install and setup. Can see new episode listings of novelas, etc. But it states that the script failed. Same message as stated by gosub2053 and newdutch01.
(2013-09-14, 03:34)aeroric Wrote: [ -> ]a parte de assinantes não funciona. da erro ao abrir o video. as outras funcionam ok.
(2013-09-14, 16:31)newdutch01 Wrote: [ -> ]I have download it and I don't get errors anymore but it need the login and pass of globotv it seems. Thanks anyway for your work
(2013-09-16, 16:04)Tanaka30 Wrote: [ -> ]Hi, I just install the new 5.5 this morning. Still not working? Asking for password for 'assinante'
Not sure what's wrong.... Thank you
17:07:38 T:8080 ERROR: Playlist Player: skipping unplayable item: 2, path [plugin://plugin.video.globotv/play/2883854]
17:07:38 T:6608 NOTICE: Thread XBPyThread start, auto delete: false
17:07:38 T:6608 NOTICE: -->Python Interpreter Initialized<--
17:07:38 T:6608 NOTICE: [xbmcswift2] Request for "/play/2883876" matches rule for function "play"
17:07:38 T:6608 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
17:07:39 T:6608 WARNING: Previous line repeats 3 times.
17:07:39 T:6608 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
17:07:39 T:6608 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
17:07:40 T:6608 WARNING: Previous line repeats 2 times.
17:07:40 T:6608 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
17:07:40 T:6608 ERROR: D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py:91: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
02:22:40 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:22:40 T:5860 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
02:22:47 T:8264 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
02:22:47 T:8264 DEBUG: CApplication::ExecuteXBMCAction : Translating RunAddon($INFO[Skin.String(HomeVideosButton1)])
02:22:47 T:8264 DEBUG: CApplication::ExecuteXBMCAction : To RunAddon(plugin.video.globotv)
02:22:47 T:8264 DEBUG: Activating window ID: 10025
02:22:47 T:8264 DEBUG: ------ Window Deinit (Home.xml) ------
02:22:47 T:8264 DEBUG: CApplication::ExecuteXBMCAction : Translating SetProperty(VideosDirectLink,True)
02:22:47 T:8264 DEBUG: CApplication::ExecuteXBMCAction : To SetProperty(VideosDirectLink,True)
02:22:47 T:8264 DEBUG: ------ Window Init (MyVideoNav.xml) ------
02:22:47 T:8264 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
02:22:47 T:8264 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.globotv)
02:22:47 T:8264 DEBUG: ParentPath = [plugin://plugin.video.globotv]
02:22:47 T:8264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/','1','')
02:22:47 T:8264 INFO: initializing python engine.
02:22:47 T:8264 DEBUG: new python thread created. id=7
02:22:47 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=7) plugin...
02:22:47 T:6048 NOTICE: Thread XBPyThread start, auto delete: false
02:22:47 T:6048 DEBUG: Python thread: start processing
02:22:47 T:6048 NOTICE: -->Python Interpreter Initialized<--
02:22:47 T:6048 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:22:47 T:6048 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:22:47 T:6048 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:22:47 T:6048 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:22:48 T:6048 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:22:48 T:6048 DEBUG: [xbmcswift2] Handling incoming request for /
02:22:48 T:6048 NOTICE: [xbmcswift2] Request for "/" matches rule for function "index"
02:22:49 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
02:22:49 T:6048 INFO: Scriptresult: Success
02:22:49 T:8264 DEBUG: Saving fileitems [plugin://plugin.video.globotv]
02:22:49 T:8264 DEBUG: -- items: 15, sort method: 0, ascending: false
02:22:49 T:4436 NOTICE: Thread Background Loader start, auto delete: false
02:22:49 T:6048 INFO: Python script stopped
02:22:49 T:6048 DEBUG: Thread XBPyThread 6048 terminating
02:22:49 T:8264 DEBUG: waiting for python thread 7 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:22:49 T:8264 DEBUG: python thread 7 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:22:49 T:4436 DEBUG: Thread Background Loader 4436 terminating
02:22:50 T:1988 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
02:22:50 T:1988 DEBUG: Suspended the Sink
02:22:53 T:8264 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
02:22:53 T:8264 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.globotv/category/novelas)
02:22:53 T:8264 DEBUG: ParentPath = [plugin://plugin.video.globotv]
02:22:53 T:5860 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/category/novelas','2','')
02:22:53 T:5860 INFO: initializing python engine.
02:22:53 T:5860 DEBUG: new python thread created. id=8
02:22:53 T:5860 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=8) plugin...
02:22:53 T:3956 NOTICE: Thread XBPyThread start, auto delete: false
02:22:53 T:3956 DEBUG: Python thread: start processing
02:22:53 T:3956 NOTICE: -->Python Interpreter Initialized<--
02:22:53 T:3956 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:22:53 T:3956 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:22:53 T:3956 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:22:53 T:3956 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:22:53 T:3956 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:22:53 T:3956 DEBUG: [xbmcswift2] Handling incoming request for /category/novelas
02:22:53 T:3956 NOTICE: [xbmcswift2] Request for "/category/novelas" matches rule for function "list_shows"
02:22:54 T:8264 DEBUG: ------ Window Init (DialogBusy.xml) ------
02:22:54 T:5860 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
02:22:54 T:3956 INFO: Scriptresult: Success
02:22:54 T:3552 NOTICE: Thread Background Loader start, auto delete: false
02:22:54 T:3956 INFO: Python script stopped
02:22:54 T:3956 DEBUG: Thread XBPyThread 3956 terminating
02:22:54 T:8264 DEBUG: waiting for python thread 8 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:22:54 T:8264 DEBUG: python thread 8 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:22:54 T:3552 DEBUG: Thread Background Loader 3552 terminating
02:22:54 T:8264 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
02:22:54 T:5860 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://s2.glbimg.com
02:22:54 T:8824 INFO: Previous line repeats 1 times.
02:22:54 T:8824 NOTICE: Thread Jobworker start, auto delete: true
02:22:54 T:8824 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://s2.glbimg.com
02:22:54 T:2348 NOTICE: Thread Jobworker start, auto delete: true
02:22:54 T:2348 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://s2.glbimg.com
02:22:55 T:5860 DEBUG: CurlFile::Open(101E05F0) http://s2.glbimg.com/-Il3iqBTgke-uYYn5EjwfC8PZ0r--JST546O0fRpOOpRIw6juK_iFwLKyllTJvCM/s2.glbimg.com/boU2L_ckapBwrOeElxZlyhJTB5Q=/s.glbimg.com/vi/mk/program/3325/logotipo_xs/2/45x34.png
02:22:55 T:7972 DEBUG: CurlFile::Open(088A1C58) http://s2.glbimg.com/Y5r1Mc8KHTrnmLLftlXfGNPL9Uufl6tpwWFwt-YFfq1NIG99IlOe8P90J6nJ37yX/s2.glbimg.com/NELI_blF4v1UQviPC21orcMmG7U=/s.glbimg.com/vi/mk/program/5173/logotipo_xs/2/45x34.png
02:22:55 T:8824 DEBUG: CurlFile::Open(088A1FD0) http://s2.glbimg.com/-r_N9c8y1s1Aa5br7ceZpRkBnv3oWxdbT-mWotjbk5-HMOio92F2zkey78uredHi/s2.glbimg.com/MvELe8hRkOj2qdQHL6vPaMTdop0=/s.glbimg.com/vi/mk/program/3171/logotipo_xs/6/45x34.png
02:22:55 T:2348 DEBUG: CurlFile::Open(10240908) http://s2.glbimg.com/9FqZ4CutrVk3wgpMUrXSWvv-kGyEW_nu1dUmRnCDzFEoogczt6Ewb55X4bdKD2LI/s2.glbimg.com/X7w9DEX8yzB1YQxas6CxPOd6olw=/s.glbimg.com/vi/mk/program/5764/logotipo_xs/2/45x34.png
02:22:55 T:5860 DEBUG: Caching image 'http://s2.glbimg.com/-Il3iqBTgke-uYYn5EjwfC8PZ0r--JST546O0fRpOOpRIw6juK_iFwLKyllTJvCM/s2.glbimg.com/boU2L_ckapBwrOeElxZlyhJTB5Q=/s.glbimg.com/vi/mk/program/3325/logotipo_xs/2/45x34.png' to 'c/c82d2d49.jpg':
02:22:55 T:5860 DEBUG: cached image 'special://masterprofile/Thumbnails/c/c82d2d49.jpg' size 34x26
02:22:55 T:7972 DEBUG: Caching image 'http://s2.glbimg.com/Y5r1Mc8KHTrnmLLftlXfGNPL9Uufl6tpwWFwt-YFfq1NIG99IlOe8P90J6nJ37yX/s2.glbimg.com/NELI_blF4v1UQviPC21orcMmG7U=/s.glbimg.com/vi/mk/program/5173/logotipo_xs/2/45x34.png' to 'd/dbe09da8.jpg':
02:22:55 T:7972 DEBUG: cached image 'special://masterprofile/Thumbnails/d/dbe09da8.jpg' size 34x26
02:22:55 T:8824 DEBUG: Caching image 'http://s2.glbimg.com/-r_N9c8y1s1Aa5br7ceZpRkBnv3oWxdbT-mWotjbk5-HMOio92F2zkey78uredHi/s2.glbimg.com/MvELe8hRkOj2qdQHL6vPaMTdop0=/s.glbimg.com/vi/mk/program/3171/logotipo_xs/6/45x34.png' to '1/136509df.jpg':
02:22:55 T:8824 DEBUG: cached image 'special://masterprofile/Thumbnails/1/136509df.jpg' size 34x26
02:22:55 T:2348 DEBUG: Caching image 'http://s2.glbimg.com/9FqZ4CutrVk3wgpMUrXSWvv-kGyEW_nu1dUmRnCDzFEoogczt6Ewb55X4bdKD2LI/s2.glbimg.com/X7w9DEX8yzB1YQxas6CxPOd6olw=/s.glbimg.com/vi/mk/program/5764/logotipo_xs/2/45x34.png' to '1/199d7234.png':
02:22:55 T:2348 DEBUG: cached image 'special://masterprofile/Thumbnails/1/199d7234.png' size 34x26
02:22:56 T:8264 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
02:22:56 T:8264 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.globotv/rede-globo/amor-a-vida)
02:22:56 T:8264 DEBUG: ParentPath = [plugin://plugin.video.globotv/category/novelas]
02:22:56 T:7972 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/rede-globo/amor-a-vida','3','')
02:22:56 T:7972 INFO: initializing python engine.
02:22:56 T:7972 DEBUG: new python thread created. id=9
02:22:56 T:7972 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=9) plugin...
02:22:56 T:8268 NOTICE: Thread XBPyThread start, auto delete: false
02:22:56 T:8268 DEBUG: Python thread: start processing
02:22:56 T:8268 NOTICE: -->Python Interpreter Initialized<--
02:22:56 T:8268 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:22:56 T:8268 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:22:56 T:8268 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:22:56 T:8268 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:22:57 T:8268 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:22:57 T:8268 DEBUG: [xbmcswift2] Handling incoming request for /rede-globo/amor-a-vida
02:22:57 T:8268 NOTICE: [xbmcswift2] Request for "/rede-globo/amor-a-vida" matches rule for function "list_rails"
02:22:57 T:7972 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
02:22:57 T:8268 INFO: Scriptresult: Success
02:22:57 T:752 NOTICE: Thread Background Loader start, auto delete: false
02:22:57 T:752 DEBUG: Thread Background Loader 752 terminating
02:22:57 T:8268 INFO: Python script stopped
02:22:57 T:8268 DEBUG: Thread XBPyThread 8268 terminating
02:22:57 T:8264 DEBUG: waiting for python thread 9 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:22:57 T:8264 DEBUG: python thread 9 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:22:58 T:8264 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
02:22:58 T:8264 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.globotv/rede-globo/amor-a-vida/519ae95ae9bde479f200000a)
02:22:58 T:8264 DEBUG: ParentPath = [plugin://plugin.video.globotv/rede-globo/amor-a-vida]
02:22:58 T:2348 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/rede-globo/amor-a-vida/519ae95ae9bde479f200000a','4','')
02:22:58 T:2348 INFO: initializing python engine.
02:22:58 T:2348 DEBUG: new python thread created. id=10
02:22:58 T:2348 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=10) plugin...
02:22:58 T:7752 NOTICE: Thread XBPyThread start, auto delete: false
02:22:58 T:7752 DEBUG: Python thread: start processing
02:22:58 T:7752 NOTICE: -->Python Interpreter Initialized<--
02:22:58 T:7752 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:22:58 T:7752 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:22:58 T:7752 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:22:58 T:7752 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:22:58 T:7752 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:22:58 T:7752 DEBUG: [xbmcswift2] Handling incoming request for /rede-globo/amor-a-vida/519ae95ae9bde479f200000a
02:22:58 T:7752 NOTICE: [xbmcswift2] Request for "/rede-globo/amor-a-vida/519ae95ae9bde479f200000a" matches rule for function "list_rail_videos"
02:22:58 T:7752 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:22:58 T:8264 DEBUG: ------ Window Init (DialogBusy.xml) ------
02:23:01 T:7752 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:03 T:8264 WARNING: Previous line repeats 1 times.
02:23:03 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:04 T:7752 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:04 T:7752 DEBUG: LocalizeStrings: no translation available in currently set gui language, at path D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\resources\language\Portuguese (Brazil)
02:23:04 T:7752 DEBUG: LocalizeStrings: no strings.po file exist at D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\resources\language\English, fallback to strings.xml
02:23:04 T:2348 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
02:23:04 T:7752 INFO: Scriptresult: Success
02:23:04 T:8264 DEBUG: Saving fileitems [plugin://plugin.video.globotv/rede-globo/amor-a-vida/519ae95ae9bde479f200000a]
02:23:04 T:8264 DEBUG: -- items: 16, sort method: 0, ascending: false
02:23:04 T:8264 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=10
02:23:04 T:8932 NOTICE: Thread Background Loader start, auto delete: false
02:23:04 T:8932 DEBUG: Thread Background Loader 8932 terminating
02:23:04 T:7752 INFO: Python script stopped
02:23:04 T:7752 DEBUG: Thread XBPyThread 7752 terminating
02:23:04 T:8264 DEBUG: waiting for python thread 10 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:23:04 T:8264 DEBUG: python thread 10 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:23:04 T:8264 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
02:23:05 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:23:05 T:5860 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://s01.video.glbimg.com
02:23:05 T:8824 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://s02.video.glbimg.com
02:23:05 T:5860 DEBUG: CurlFile::Open(10240908) http://s01.video.glbimg.com/180x108/2878616.jpg
02:23:06 T:8264 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
02:23:06 T:8264 DEBUG: CGUIWindowVideoBase::OnPlayMedia plugin://plugin.video.globotv/play/2885661
02:23:06 T:8264 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
02:23:06 T:8264 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
02:23:06 T:8264 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
02:23:06 T:8264 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
02:23:06 T:8264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/play/2885661','5','')
02:23:06 T:8264 INFO: initializing python engine.
02:23:06 T:8264 DEBUG: new python thread created. id=11
02:23:06 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=11) plugin...
02:23:06 T:8740 NOTICE: Thread XBPyThread start, auto delete: false
02:23:06 T:8740 DEBUG: Python thread: start processing
02:23:06 T:8740 NOTICE: -->Python Interpreter Initialized<--
02:23:06 T:8740 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:23:06 T:8740 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:23:06 T:8740 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:23:06 T:8740 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:23:06 T:5860 DEBUG: Caching image 'http://s01.video.glbimg.com/180x108/2878616.jpg' to '6/6cba3c9a.jpg':
02:23:06 T:5860 DEBUG: cached image 'special://masterprofile/Thumbnails/6/6cba3c9a.jpg' size 180x108
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:23:06 T:8740 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:23:06 T:8740 DEBUG: [xbmcswift2] Handling incoming request for /play/2885661
02:23:06 T:8740 NOTICE: [xbmcswift2] Request for "/play/2885661" matches rule for function "play"
02:23:06 T:8824 DEBUG: CurlFile::Open(10240908) http://s02.video.glbimg.com/180x108/2885661.jpg
02:23:07 T:8824 DEBUG: Caching image 'http://s02.video.glbimg.com/180x108/2885661.jpg' to '7/71db2c8c.jpg':
02:23:07 T:8824 DEBUG: cached image 'special://masterprofile/Thumbnails/7/71db2c8c.jpg' size 180x108
02:23:07 T:8264 DEBUG: DialogProgress::StartModal called
02:23:07 T:8264 DEBUG: ------ Window Init (DialogProgress.xml) ------
02:23:07 T:8264 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
02:23:10 T:8740 DEBUG: [plugin.video.globotv] playlist found, adding 4 items: [2885575, 2885593, 2885608, 2885645]
02:23:10 T:8740 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
02:23:10 T:8740 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
02:23:10 T:8740 ERROR: NEWADDON Invalid Date Format "None"
02:23:10 T:8740 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
02:23:10 T:8740 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
02:23:10 T:8740 DEBUG: [plugin.video.globotv] setting resolved url for first item 2885575
02:23:10 T:8740 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:10 T:8740 DEBUG: [plugin.video.globotv] resolving video: 2885575
02:23:10 T:8228 WARNING: Previous line repeats 2 times.
02:23:10 T:8228 DEBUG: Thread CRemoteControl 8228 terminating
02:23:13 T:8740 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:13 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:13 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:23:14 T:8740 DEBUG: [plugin.video.globotv] resource ids: 5259ef22dd23817ca8000a03
02:23:14 T:8740 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:14 T:8740 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:14 T:8740 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:14 T:8740 DEBUG: [plugin.video.globotv] retrying authentication
02:23:14 T:8740 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:15 T:8740 WARNING: Previous line repeats 2 times.
02:23:15 T:8740 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:15 T:8740 DEBUG: [plugin.video.globotv] resource ids: 5259ef22dd23817ca8000a03
02:23:15 T:8740 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:15 T:8740 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:15 T:8740 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:15 T:8740 ERROR: D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py:91: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
plugin.notify(e.message)
02:23:15 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned failure
02:23:15 T:8264 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.globotv/play/2885661]
02:23:15 T:8740 INFO: Scriptresult: Success
02:23:15 T:8264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/play/2885593','6','')
02:23:15 T:8264 INFO: initializing python engine.
02:23:15 T:8264 DEBUG: new python thread created. id=12
02:23:15 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=12) plugin...
02:23:15 T:5336 NOTICE: Thread XBPyThread start, auto delete: false
02:23:15 T:5336 DEBUG: Python thread: start processing
02:23:15 T:8740 INFO: Python script stopped
02:23:15 T:8740 DEBUG: Thread XBPyThread 8740 terminating
02:23:15 T:8264 DEBUG: waiting for python thread 11 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:23:15 T:8264 DEBUG: python thread 11 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:23:15 T:8264 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
02:23:15 T:1988 DEBUG: Resumed the Sink
02:23:15 T:1988 DEBUG: CSoftAE::Run - Sink restart flagged
02:23:15 T:1988 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
02:23:15 T:1988 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 1117772
02:23:15 T:5336 NOTICE: -->Python Interpreter Initialized<--
02:23:15 T:5336 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:23:15 T:1988 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
02:23:15 T:1988 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
02:23:15 T:1988 DEBUG: Audio Device : Alto-falantes (Realtek High Definition Audio)
02:23:15 T:1988 DEBUG: Sample Rate : 44100
02:23:15 T:1988 DEBUG: Sample Format : AE_FMT_FLOAT
02:23:15 T:1988 DEBUG: Bits Per Sample : 32
02:23:15 T:1988 DEBUG: Valid Bits/Samp : 32
02:23:15 T:1988 DEBUG: Channel Count : 2
02:23:15 T:1988 DEBUG: Block Align : 8
02:23:15 T:1988 DEBUG: Avg. Bytes Sec : 352800
02:23:15 T:1988 DEBUG: Samples/Block : 32
02:23:15 T:1988 DEBUG: Format cBSize : 22
02:23:15 T:1988 DEBUG: Channel Layout : FL,FR
02:23:15 T:1988 DEBUG: Channel Mask : 3
02:23:15 T:1988 DEBUG: Frames : 441
02:23:15 T:1988 DEBUG: Frame Samples : 882
02:23:15 T:1988 DEBUG: Frame Size : 8
02:23:15 T:1988 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
02:23:15 T:1988 DEBUG: Output Device : Speakers - Alto-falantes (Realtek High Definition Audio)
02:23:15 T:1988 DEBUG: Channel Layout: FL,FR
02:23:15 T:1988 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
02:23:15 T:1988 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
02:23:15 T:5336 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:23:15 T:5336 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:23:15 T:5336 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:23:15 T:1988 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
02:23:15 T:8264 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:23:16 T:5336 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:23:16 T:5336 DEBUG: [xbmcswift2] Handling incoming request for /play/2885593
02:23:16 T:5336 NOTICE: [xbmcswift2] Request for "/play/2885593" matches rule for function "play"
02:23:16 T:5336 DEBUG: [plugin.video.globotv] setting resolved url for first item 2885593
02:23:16 T:5336 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:16 T:5336 DEBUG: [plugin.video.globotv] resolving video: 2885593
02:23:17 T:5336 WARNING: Previous line repeats 2 times.
02:23:17 T:5336 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:17 T:5336 DEBUG: [plugin.video.globotv] resource ids: 5259f314dd23817cb9000836
02:23:17 T:5336 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:17 T:5336 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:17 T:5336 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:17 T:5336 DEBUG: [plugin.video.globotv] retrying authentication
02:23:17 T:5336 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:17 T:8264 WARNING: Previous line repeats 2 times.
02:23:17 T:8264 DEBUG: DialogProgress::StartModal called
02:23:17 T:8264 DEBUG: ------ Window Init (DialogProgress.xml) ------
02:23:17 T:5336 ERROR: D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py:91: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
02:23:17 T:5336 INFO: Scriptresult: Success
02:23:17 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned failure
02:23:17 T:8264 ERROR: Playlist Player: skipping unplayable item: 1, path [plugin://plugin.video.globotv/play/2885593]
02:23:17 T:8264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/play/2885608','7','')
02:23:17 T:8264 INFO: initializing python engine.
02:23:17 T:8264 DEBUG: new python thread created. id=13
02:23:17 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=13) plugin...
02:23:17 T:8836 NOTICE: Thread XBPyThread start, auto delete: false
02:23:17 T:8836 DEBUG: Python thread: start processing
02:23:17 T:5336 INFO: Python script stopped
02:23:17 T:5336 DEBUG: Thread XBPyThread 5336 terminating
02:23:17 T:8264 DEBUG: waiting for python thread 12 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:23:17 T:8264 DEBUG: python thread 12 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:23:18 T:8836 NOTICE: -->Python Interpreter Initialized<--
02:23:18 T:8836 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:23:18 T:8836 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:23:18 T:8836 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:23:18 T:8836 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:23:18 T:8264 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:23:18 T:8836 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:23:18 T:8836 DEBUG: [xbmcswift2] Handling incoming request for /play/2885608
02:23:18 T:8836 NOTICE: [xbmcswift2] Request for "/play/2885608" matches rule for function "play"
02:23:18 T:8836 DEBUG: [plugin.video.globotv] setting resolved url for first item 2885608
02:23:18 T:8836 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:18 T:8836 DEBUG: [plugin.video.globotv] resolving video: 2885608
02:23:19 T:8836 WARNING: Previous line repeats 2 times.
02:23:19 T:8836 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:19 T:8264 DEBUG: DialogProgress::StartModal called
02:23:19 T:8264 DEBUG: ------ Window Init (DialogProgress.xml) ------
02:23:19 T:8836 DEBUG: [plugin.video.globotv] resource ids: 5259f679dd23817cae000958
02:23:19 T:8836 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:19 T:8836 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:19 T:8836 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:19 T:8836 DEBUG: [plugin.video.globotv] retrying authentication
02:23:19 T:8836 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:20 T:8264 WARNING: Previous line repeats 2 times.
02:23:20 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:21 T:8264 DEBUG: Keyboard: scancode: 38, sym: 0134, unicode: 0000, modifier: 100
02:23:21 T:8264 DEBUG: CApplication::OnKey: alt-leftalt (4f0d4) pressed, action is
02:23:21 T:8836 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:21 T:8264 DEBUG: CWinEventsWin32::WndProcWindow is active
02:23:21 T:8264 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
02:23:21 T:8836 DEBUG: [plugin.video.globotv] resource ids: 5259f679dd23817cae000958
02:23:21 T:8836 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:21 T:8836 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:21 T:8836 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:21 T:8836 ERROR: D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py:91: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
02:23:21 T:8836 INFO: Scriptresult: Success
02:23:21 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned failure
02:23:21 T:8264 ERROR: Playlist Player: skipping unplayable item: 2, path [plugin://plugin.video.globotv/play/2885608]
02:23:21 T:8264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Globo.tv('plugin://plugin.video.globotv/play/2885645','8','')
02:23:21 T:8264 INFO: initializing python engine.
02:23:21 T:8264 DEBUG: new python thread created. id=14
02:23:21 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Globo.tv (id=14) plugin...
02:23:21 T:6816 NOTICE: Thread XBPyThread start, auto delete: false
02:23:21 T:6816 DEBUG: Python thread: start processing
02:23:21 T:8836 INFO: Python script stopped
02:23:21 T:8836 DEBUG: Thread XBPyThread 8836 terminating
02:23:21 T:8264 DEBUG: waiting for python thread 13 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:23:21 T:8264 DEBUG: python thread 13 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:23:21 T:6816 NOTICE: -->Python Interpreter Initialized<--
02:23:21 T:6816 DEBUG: XBPyThread::Process - The source file to load is D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py
02:23:21 T:6816 DEBUG: XBPyThread::Process - Setting the Python path to D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.requests\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;D:\matzabal\AppData\Roaming\XBMC\addons\script.module.feedparser\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
02:23:21 T:6816 DEBUG: XBPyThread::Process - Entering source directory D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5
02:23:21 T:6816 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.globotv" dependent on version 2.0 of the xbmc.python api
02:23:21 T:8264 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/" named "index" pointing to function "index"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/play/<vid>" named "play" pointing to function "play"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/category/<slug>" named "list_shows" pointing to function "list_shows"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>" named "list_rails" pointing to function "list_rails"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/offer/<slug>/<filter>" named "list_offer_videos" pointing to function "list_offer_videos"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>/page/<page>" named "list_rail_videos_page" pointing to function "list_rail_videos"
02:23:21 T:6816 DEBUG: [xbmcswift2] Adding url rule "/<channel>/<show>/<rail>" named "list_rail_videos" pointing to function "list_rail_videos"
02:23:21 T:6816 DEBUG: [xbmcswift2] Handling incoming request for /play/2885645
02:23:21 T:6816 NOTICE: [xbmcswift2] Request for "/play/2885645" matches rule for function "play"
02:23:21 T:6816 DEBUG: [plugin.video.globotv] setting resolved url for first item 2885645
02:23:21 T:6816 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:21 T:6816 DEBUG: [plugin.video.globotv] resolving video: 2885645
02:23:23 T:8264 WARNING: Previous line repeats 2 times.
02:23:23 T:8264 DEBUG: DialogProgress::StartModal called
02:23:23 T:8264 DEBUG: ------ Window Init (DialogProgress.xml) ------
02:23:23 T:6816 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:23 T:6816 DEBUG: [plugin.video.globotv] resource ids: 525a00d592144754e300089b
02:23:23 T:6816 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:23 T:6816 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:23 T:6816 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:23 T:6816 DEBUG: [plugin.video.globotv] retrying authentication
02:23:23 T:6816 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
02:23:24 T:6816 WARNING: Previous line repeats 2 times.
02:23:24 T:6816 DEBUG: [plugin.video.globotv] successfully authenticated
02:23:24 T:6816 DEBUG: [plugin.video.globotv] resource ids: 525a00d592144754e300089b
02:23:24 T:6816 DEBUG: [plugin.video.globotv] return: {"http_status_code":400,"message":"Player not recognized","code":"PNR"}
02:23:24 T:6816 ERROR: [plugin.video.globotv] Request error: [400] Player not recognized
02:23:24 T:6816 DEBUG: [plugin.video.globotv] cleaning globo id
02:23:24 T:6816 ERROR: D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py:91: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
02:23:24 T:6816 INFO: Scriptresult: Success
02:23:24 T:8264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned failure
02:23:24 T:8264 ERROR: Playlist Player: skipping unplayable item: 3, path [plugin://plugin.video.globotv/play/2885645]
02:23:24 T:8264 DEBUG: Playlist Player: no more playable items... aborting playback
02:23:24 T:9100 NOTICE: Thread Background Loader start, auto delete: false
02:23:24 T:9100 DEBUG: Thread Background Loader 9100 terminating
02:23:24 T:6816 INFO: Python script stopped
02:23:24 T:6816 DEBUG: Thread XBPyThread 6816 terminating
02:23:24 T:8264 DEBUG: waiting for python thread 14 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) to stop
02:23:24 T:8264 DEBUG: python thread 14 (D:\matzabal\AppData\Roaming\XBMC\addons\plugin.video.globotv-plugin.video.globotv-0.5.5\addon.py) destructed
02:23:24 T:8264 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
02:23:25 T:8264 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
02:23:25 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s2.glbimg.com (easy=09615AA8, multi=005486E8)
02:23:25 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s2.glbimg.com (easy=094B3F70, multi=005482A8)
02:23:25 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s2.glbimg.com (easy=096312E8, multi=005483B8)
02:23:25 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s2.glbimg.com (easy=09440048, multi=00548550)
02:23:26 T:1988 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
02:23:26 T:1988 DEBUG: Suspended the Sink
02:23:28 T:8264 DEBUG: CJoystick::Initialize : No Joystick found
02:23:28 T:8264 DEBUG: CWinEventsWin32::WndProcWindow is active
02:23:28 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:23:29 T:1988 DEBUG: Resumed the Sink
02:23:29 T:1988 DEBUG: CSoftAE::Run - Sink restart flagged
02:23:29 T:1988 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
02:23:29 T:1988 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 1117772
02:23:29 T:1988 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
02:23:29 T:1988 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
02:23:29 T:1988 DEBUG: Audio Device : Alto-falantes (Realtek High Definition Audio)
02:23:29 T:1988 DEBUG: Sample Rate : 44100
02:23:29 T:1988 DEBUG: Sample Format : AE_FMT_FLOAT
02:23:29 T:1988 DEBUG: Bits Per Sample : 32
02:23:29 T:1988 DEBUG: Valid Bits/Samp : 32
02:23:29 T:1988 DEBUG: Channel Count : 2
02:23:29 T:1988 DEBUG: Block Align : 8
02:23:29 T:1988 DEBUG: Avg. Bytes Sec : 352800
02:23:29 T:1988 DEBUG: Samples/Block : 32
02:23:29 T:1988 DEBUG: Format cBSize : 22
02:23:29 T:1988 DEBUG: Channel Layout : FL,FR
02:23:29 T:1988 DEBUG: Channel Mask : 3
02:23:29 T:1988 DEBUG: Frames : 441
02:23:29 T:1988 DEBUG: Frame Samples : 882
02:23:29 T:1988 DEBUG: Frame Size : 8
02:23:29 T:1988 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
02:23:29 T:1988 DEBUG: Output Device : Speakers - Alto-falantes (Realtek High Definition Audio)
02:23:29 T:1988 DEBUG: Channel Layout: FL,FR
02:23:29 T:1988 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
02:23:29 T:1988 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
02:23:29 T:1988 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
02:23:29 T:8264 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
02:23:30 T:8264 DEBUG: Keyboard: scancode: 38, sym: 0134, unicode: 0000, modifier: 100
02:23:30 T:8264 DEBUG: CApplication::OnKey: alt-leftalt (4f0d4) pressed, action is
02:23:30 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:30 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:23:30 T:8264 DEBUG: CWinEventsWin32::WndProcWindow is active
02:23:30 T:8264 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
02:23:35 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:35 T:7972 DEBUG: Thread Jobworker 7972 terminating (autodelete)
02:23:35 T:2348 DEBUG: Thread Jobworker 2348 terminating (autodelete)
02:23:36 T:8264 DEBUG: CJoystick::Initialize : No Joystick found
02:23:36 T:8264 DEBUG: CWinEventsWin32::WndProcWindow is active
02:23:36 T:8264 DEBUG: ------ Window Init (Pointer.xml) ------
02:23:36 T:5860 DEBUG: Thread Jobworker 5860 terminating (autodelete)
02:23:36 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s01.video.glbimg.com (easy=00ACB3B8, multi=00548660)
02:23:37 T:8824 DEBUG: Thread Jobworker 8824 terminating (autodelete)
02:23:37 T:8264 DEBUG: Keyboard: scancode: 38, sym: 0134, unicode: 0000, modifier: 100
02:23:37 T:8264 DEBUG: CApplication::OnKey: alt-leftalt (4f0d4) pressed, action is
02:23:37 T:8264 DEBUG: ------ Window Deinit (Pointer.xml) ------
02:23:37 T:8264 DEBUG: CWinEventsWin32::WndProcWindow is active
02:23:37 T:8264 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
02:23:37 T:8264 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://s02.video.glbimg.com (easy=00AD4378, multi=00548880)
02:23:39 T:1988 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
02:23:39 T:1988 DEBUG: Suspended the Sink
