2012-11-22, 08:34
Ok, so I've looked over the seach, and I've tried the fixes listed within them in theses threads with the following issues.
http://forum.xbmc.org/showthread.php?tid=93249
When I run xrandr all I can get is "can't open display" even with sudo, all commands give the error "Can't open display"
http://forum.xbmc.org/showthread.php?tid...ght=dv6000
same thing. This is running on an HP dv6000 laptop with an nVidia graphics card. The boot logo is displayed throught he VGA port (that is the end goal), but as soon as the GUI loads for xbmc, there's nothing. The terminal that I load works with the VGA without any issues either. It's running XBMC 11.0 Eden, on XBMCUbuntu.
I've tried everything I could search for but nothings worked. considering just putting windows back on it and having it auto launch XBMC at start up if that's easier, I'm not a linux user too frequently...
