2012-11-22, 15:21
Hello,
I'm pretty new to XBMC but have experimented a bit already.
I mainly use it with a dedicated music jukebox pc.
I'm using Windows 8 with a Touch Screen.
My trouble is that XBMC has a strange way of scrolling playlist with the mouse (and with the finger) when the mouse pointer is active.
When the cursor is active, if you tap within a playlist to scroll through the list, it doesn' scroll but follow your mouse or your finger from file to file (I'm not talking about using the scroll wheel).
When the cursor disappears (5-10 seconds), I'm able to tap in the playlist and scroll as expected.
Does anyone know how I can fix this?
Thanks,
Sheugel
Thanks,
Sheugel
