2012-11-23, 22:50
I have 3 profiles on my Windows XBMC. When at the loginscreen, XBMC receives airplay without problems. But after logging on, no music comes from the speakers although XBMC is visible on my iPhone.
If I disable the loginscreen, airplay works fine in XBMC. But not after changing user via the loginscreen.
The easy solution would be to disable the login screen and erase the other profiles, but my family really enjoys their own profile, so they don't have to put up with my eternal tweaking of the skin.
So I hope to get some help from someone with an understanding of the airplay service. Log is here: http://xbmclogs.com/show.php?id=15347
