Full Version: XBMCbuntu suddenly won't boot
My relatively new XBMCbuntu (Eden v11) box was working fine last night, but this morning I turn it on and get this message while turning it on:
* Checking battery state ...                    [ OK ]
* Stopping System V runlevel compatibility      [ OK ]
* Starting Mount network filesystems            [ OK ]
* Stopping Mount network filesystems            [ OK ]
It never loads the GUI, just sits on a black screen with this.
I can ssh into the box, but don't know what to do.
Any help? What can I provide to give more insight?
Is the drive corrupted? It started to mount and then stopped?
Can you get to your userdata folder for a backup? SFTP it all off and reinstall xbmcbuntu?
Which drive would be corrupt? I have the OS installed on a brand new USB stick.
Is the complaint about the "network" filesystems? I have all my media on a samba share on a separate computer. That drive and computer are working fine (accessing it from my laptop right now)
I could reinstall, but I just reinstalled yesterday. Yesterday I decided to try an "apt-get dist-upgrade" which failed because the USB stick ran out of space.
hmm... maybe the stick IS corrupt.. ?
I never do a dist upgrade, in past experience it can bugger the system right up.
i would do a re-install and stay away from dist-upgrade
Matt
if the stick ran out of space, your install most probably is corrupt now
I'm re-reinstalling onto the same stick. I assume the stick itself won't be corrupted after running out of disk space.
Thanks for the advice about never doing a dist-upgrade.
Does XBMC get minor updates after its original release? What's the proper way of updating?
i boot into xbmcbuntu and do it via package manager but you can follow some instructions here
http://wiki.xbmc.org/index.php?title=XBM..._XBMCbuntu
Matt
